91 350 1/4 mile time...
What should I run. With a cutout and k&n i ran a 14.76 with a 2.2 60'. Now i've got hedmenn 1 5/8 hedders, no cats hooker catback and removed air pump. Full tune up was done, new plug wires, rotor and cap, plugs etc.. New fuel pump. What should i run?
Car: Z28
my 91 L98 currently runs the same times as you, see my sig for best time thus far.
in the upcoming 2-3 months, i am going to be putting on AS&M semi-siamese runners, accel superram intake manifold, and SLP 1 5/8 headers. I'm expecting 14.0x's (hopefully!).
To run mid 13's I think you are probably looking at a set of heads, or a cam swap.
Car: 93 Mustang GT
Engine: 5.0
My friend ran a 14.6@96 I think with no air filters, chip, and air foil in his 90 L98 IROC. He has yet to run it with ported stock heads and SLP cam. I raced him on street and was pushing him down the road. He still has stock exhaust though...killing it bad.
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Originally posted by 91-GasGuzlinZ-28
What do i need to get to run mid 13's in the 1/4?
how much do you think a transmission shop would charge me to put in a torque converter, a tranny cooler, a shift kit, and a corvette servo? my 700r4 runs real nice, but i want to it last longer..
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
ThirdGenZ28 92 is right on the money. My car has a lot of the same mods. I still have the factory converter, manifolds and 160K miles. Traction and iced plenum make a huge difference. The 1/8 on my 13.996 1/4 pass was a 8.9XX. I just added a new fuel pump and cat-back so hopefully I'll be able to get out to the track and take advantage of the cooler weather.
I'll second that traction issue!!!
My 85 IROC ( '87 L98 long block ) ran a best of 14.6 @ 94.5 mph the other night. This was the 1st time I've run this car. Wanted to get a baseline before I started my mods.
I hot lapped, so icing the plenum makes a HUGE difference. And in my case, since my 700 would not shift into Drive at WOT when manually shifting, I'm sure when I get the T5 in it will be worth AT LEAST a few tenths.
My best run was leaving it in Drive ( so it would shift ) and shift points sucked at like 4200 RPM or so. Previous owner had the tranny rebuilt, but it's probably just a stocker that was exchanged. Since my 350 has some mild port work on the heads, plenum, intake etc, it wants to pull farther than 4200 RPM.
With my 275/40/17 BFG KDWS 's in the rear, traction was a DREAM!!! My 14.6 run was only a 2.19 60 ft time, and I left at idle, and ended up having to let off when I hit 2nd, as it got squirrly on me.
I have some headers ready to go. I might even borrow some drag radials and wheels and see what it would run with traction..
Remember....... knocking a tenth off in the 60ft will gain you 2-3 tenths in the 1/4 mile ET.
With my headers, and being able to squeeze a 1.9 60 ft time, I'm fairly confident I can get the car down to a 14 flat........
HTH
HTH
I 3rd The Traction statement.
I have been lucky with my car since all I race on is street tires. Normally I hook pretty well unless some dumba$$ runs through the waterbox with out doing a burn out or they dont put enough good stuff on the track.
My Camaro ran 14.24 @97 with 3.73 gears, cheap headers, and pulleys. (which did not help my car one bit, except kill my battery every few months) On 100 shot of nitrous, I ran a 12.89 @104, on sticky tires. went 12.64 on 150 shot with the tranny starting to slip. The MPH was only 104. Let me know other times out there to see where i stand.
