what will my 1/4 times be with this combo
here it goes. this is goin into an 83 bird with a saginaw 4 speed trany and 3:08 rear gears. 91 caprice lo3 block stock bore. magnafluxed and zero decked. new pistons. shaved crank. polished lightened 305 rods. cloyed double roller chain. crane compucam 2050 cam. 1.6 roller rockers. rebuilt ported lo3 305 heads. 1.94 1.50 valves. compcams valve train. edelbrock performer rpm intake. 600 cfm holley carb. 11x6 k&n open element. full lenght headers. hooker cat back. what should i run in the 1/4 mi with this. im hoping high 13's
1 Post
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
You know everyone seems to ask the same Questions what will I run with this combo & the only Answer i can give is GO DOWN TO THE TRACK & TRY IT OUT. if you are to scared to race it then dont ask.
If you think ppl will make fun of you about how slow your car is then dont run. But you will find out that you have more ppl willing to help you at the tracks then off the track.
If nothing else Go to the track & ask about Test & tunes they are great for beginners learning how to race.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
youll need suspension modems to get soem traction plus some trans work and a posi to think about 13's
evilstuie
01-09-2020 08:29 PM
Street Lethal
04-30-2019 12:14 PM
