getting sea level times
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
does anyone know the equation for getting sea level times?i searched but only came up with a bad link.thanks to anyone who has it!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The NHRA Stock/SuperStock conversion gives a close conversion but isn't truly accurate. It converts from elevation altitude but doesn't take into effect the density altitude. If you get the density altitude of the run, the conversion will be a lot closer to an actual sea level pass.
My conversion (corrected times below) is based on a dyno correction factor. It takes into account the air conditions as well as the altitude.
The Calgary Drag Racing pages has the NHRA charts. Click on Tech Tips
Thornburg
08-25-2015 01:46 AM
