Good for 12's ??????
Im getting my L98 Rebuilt to a 383 Stroker, re-doing the heads, getting new valves (something about swirls on them for better air flow???) 3 angle valve job, roller rockers, diff. cam, hypereautectic pistons
SLP siamese runners, TPIS Big Mouth, Ported/Siamese Plenum, Suncoast Ram Air, edelbrock T.E.S headers, Catco high flow cat, borla 3" adjustable cat-back, Jet Stage II Chip.
Would this set-up be good to run 12's. Have any idea on track times? or even HP numbers
1 Post
Car: 99 Formula
Axle/Gears: 342
Depends on what cam you get. Also you'll definately need a higher stall TC if you don't already have one. What gears do you have?
1 Post
Car: 99 Formula
Axle/Gears: 342
I'd say you're going to need something in the area of 2800rpm stall or so at least. I'm no expert but I don't see you breaking into the 12s with those gears/TPI and not having a high stall TC.
Not too mention those headers (TES) aren't helping. You need something with some 1 3/4 primaries.
Ghettobird52
07-05-2024 11:18 PM
