Lookin for a 8.5" rear ...
Car: 84 Camaro Berlinetta
Engine: 377ci standard bore 383
Axle/Gears: 4.56
When i acquired my '84 Berlinetta it had a bent rearend, no problem, went to the junkyard and picked up a stock replacement for the 2.8L V6 powered 2.73 one-legger rear for 125$. MUCH later, after deciding to keep the Camaro and drag race it i picked up a stock posi, only one i could find available at the time was another 2.73 stock posi [325$], ok, will have to do for now [racing that weekend]. With this setup and "General" street radials, i've managed a best 60' of 1.94 with a best 1/8th mi. ET of 8.06 @ 90mph at Irwindale Drags [So. Cal.]. Im ready for the NEXT step, have talked with many drag racers and since im below 500hp, an 8.5" rear with Strange axles/gears are an excellant choice and much cheaper than an overkill 12-bolt rear.
So. Anyone know where i can get an 8.5" rear for my '84 Camaro? Core will suit me fine i believe, i can use the brakes [drums] off my existing rear and im getting different axles and gears anyhow. Is there anything else im forgetting or dont know about?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Third gen diff choices are stock 10 bolt 7.5"/7.625", Borg Warner 9 bolt 7.75" or a rare Dana44 8.5". Aftermarket choices are 12 bolt or ford 9".
The trouble with trying to adapt another type of diff to a third gen is that there is no way to properly attach the torque arm especially GM's cast housings.
My best times are with a beefed up 7.5" and I originally had a 3.27 geared 9 bolt going a little slower. Both diffs held up fine. I've just converted to a 9" because of an 8" converter and transbrake.
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
