how fast will i run
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
how fast will i run
im planning on putting heads, cam, intake manifold, carb, headers, high flow cat, and hooker cat back on my car. what do you think my car would run in th 1/4 mile. also what do you think the hp would be with that all done to it.thanks
Car: 84 camaro Z28
Engine: 434sbc
oh, ok. i don't really know witch products i'm going to use. im still talking to my friends dad about what would be best.
Car: 99 Formula
Axle/Gears: 342
I'd go with a Comp Cams 268XE with new heads. And the new Edelbrock EPS manifold, that's what I'm going with, with all of that you'll be mid 13s with the right heads.
Also, the Edelbrock 600 cfm should suit your needs.
Headers, SLP would be the best, but are pricey.
I think your 305 (L69) is one that will be capable of pulling a high 13/low 14 after the mods you are talking about doing.
Put as large of a cam as you can stand, World Torquer 305 heads, headers, Edelbrock intake and 600cfm carb and you should be there.
If you get eveything in and you arent where you want to be, get more gear (I think the stock L69/5speed gear is pretty good though).
Later
Doug
Later
Doug
Car: 84 camaro Z28
Engine: 434sbc
wow that would be awsome if i could get it in the 13s. i was looking to get it in at least 14s. were can i find these World Torquer 305 heads and how much do they cost. as for the headers im going with the hooker shorty headers. im not sure what cam to use. im going to talk to my friends dad about it on wednesday. i'll let you guys know what he thinks.
You can buy the worlds from Jegs. They cost $310 each, so $620 for the set.
http://www.jegs.com/cgi-bin/ncommerc...468&prmenbr=76
They come fully assembled ready to bolt on. But do yourself a favor and have them ported out a little before you put them on. They are the most expensive thing listed...but also the MOST IMPORTANT. If you want to go fast you need a good set of heads.
-Doug
-Doug
Heads are where hp is made. What about GM's Vortec heads?I've seen several supposed 305 camaros w/ them running mid 13's with them. With a little port work they really build some power, and you can get them for around $430 complete, and thats new from GM.
Car: 84 camaro Z28
Engine: 434sbc
will those vortec heads bolt up to the factory brackets and stuff like that. are they $430 a pair or for one head.
Car: 84 camaro Z28
Engine: 434sbc
were would i get the vortec intake. are the vortec heads better than the world products torker 305 heads. do the vortecs bolt right up to everything.
Fast355
12-02-2016 06:33 PM
