Another 1/4 mile estimate
What ya think this will run in 1/4 and in 1/8 if you can tell:
350 bored 40 over (357) Block has been decked
Double Hump heads (461) Port/Polished w/1.94 and 1.50 valves
280H Comp Cam
Pink Rods
Steel Crank
Forged Flat tops
Edelbrock RPM Performer Airgap Intake
Edelbrock Performer 750cfm elec choke Carb (1411)
TH350 w/transgo shift kit and 3000 stall
And I think thats it. I will probubly run slicks at the track.
Thanks.
280H Comp Cam
Pink Rods
Steel Crank
Forged Flat tops
Thanks.
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
what are the specs on the cam? what kinda compression you running? If I had to take a guess maybe mid 13's.
3.42's 10.5-11:1 CR
and we switched the cam. this one is solid lifter. the specs are:
Valve Lift= .522 Intake and .532 Exaust
Seperation=106
Duration= 244 intake (.050)
252 exaust
156 intake
164 exaust (.200)
Hope I didnt confuse ya one the specs....
Seperation=106
252 exaust
156 intake
164 exaust (.200)
86CamaroDan
09-29-2015 10:08 PM
