Bolt a twin turbo setup on your ride for $50?
Car: 1971 Chevelle
Engine: Twin Turbo 350
Axle/Gears: 12 Bolt / 3.73
Anyone in the Chicagoland area have a 3rd gen with their headers/manifolds off, or that would be willing to remove their headers/manifolds, that I could use to check fitment of a twin turbo setup? $50 for a few hours of supervised time in your engine compartment. Need to check fitment of my current dual scroll custom manifolds and take measurements to verify that new design will fit a third gen engine compartment.
Kevin
630-660-5309
Kevin
630-660-5309
Car: 89 RS
Engine: 355
Transmission: T5 B&M Shift kit with short throw
Axle/Gears: 3.73 Posi
Re: Bolt a twin turbo setup on your ride for $50?
I'm in elgin and because I'm waiting to find the right bellhousing I need, I could probably help you out if you still need it.
Car: 1971 Chevelle
Car: 89 RS
Engine: 355
just sent it, give me a shout.
Car: 89 RS
Engine: 355
I actualy have quite a bit of room. There may be an issue with the lines coming off of the master, but they can be easily moved, and for the purpose of a test fit, I would be willing to take the master off.
Car: 1971 Chevelle
We'll find out. I wouldn't ask you to pull your master cylinder. We can just set the turbos on the manifolds and take a measurement on how much further forward they need to be. I don't plan on the setup fitting perfectly, I just need to know where the issues are and how much things need to move. I appreciate the input from you guys and definetly the engine compartment to use.
Terrell351
06-13-2021 01:13 PM
bjpotter
01-22-2019 12:27 PM
Street Lethal
08-13-2015 08:28 PM
