F.S. IROC-Z Front Sway Bar 34 mm
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I have one IROC-Z front sway bar. The size of it is 34mm.
$25
Kevin
$25
Kevin
Engine: 350 TPI L98
Re: F.S. IROC-Z Front Sway Bar 34 mm
DO all 89 IROCs with the 350 TPI come with 34mm sway bar bushings? All catalogs I've seen range the 3rd gen sway bar bushings from 30mm-34mm. I bought the complete set of poly bushings for my 89 IROCs suspension except sway bar bushings and need them.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
