Suspension clunks and pops normal??
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i just re did my whole suspension with tubular LCA's with relocators, panhard, Jegster torque arm and now i get a clunk when getting on and off the gas that feels like the torque arm.. is this normal with a jegster torque arm?
i checked everything today and everything is tight. actually the shocks and sway bar endlink came a little loose but those are retightend and i still get that same clunk when moving and geting quickly off or on the gas... other than that the suspension seems to work very well.. it handles well and under acceleration you can feel the rear of the car pickup and just hoooooooook...its pretty cool
1 Post
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: Suspension clunks and pops normal??
Is that T/A adjustable, wrong pinoin angle with worn u joint? just throwing it out there
Car: 1983 trans am
the torque arm is adjustable and the pinion angle was not set with an angle finder but it does look good.... possibly the trans mount ill check it out..
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
I agree with the trans mount as the prime suspect. I have had to replace it in both of the formula's that I've owned.
Car: 1983 trans am
i was so worried about the new suspension i didnt even think to look at the trans mount. now i remember i had to do the same on my camaro
Car: 1983 trans am
u joints are definetly good checked when i had the driveshaft out so i guess il buy a poly trans mount now
Car: 1983 trans am
ok i checked the transmount and it seems ok... i will be replacing it when i put the new motor in but id really like to figure out this clunk first ... it just feels like something is loose, but ive gone over every nut and bolt twice and i cant find anything.. i dont no i think i need professional help haha
1 Post
Car: 87 GTA
Engine: 385 sbc
If you changed the torque arm on a lift like <[]> where the wheels hang,, double check the rear torque arm bolts,,, just a shot in the dark
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Well.....Do Fish get thirsty?
1 Post
Car: 87 GTA
Engine: 385 sbc
alot of shops do have roll on lifts ... Hey maniak did you ever find out whats popping?
Car: 1992 Camaro RS
Engine: 5.0l TBI
is it all poly mounts? is it a trans mount or brace? my rod ended brace mount torque arm on my old 4th gen was very noisy.
Car: 1983 trans am
I did it on the floor in my garage with jackstands. i tightened all the bolts with the axle as near rideheight as i could.
the torque arm is rodended to a sliding link mounted to the tunnel. everything else is poly mounts.
Car: 1992 Camaro RS
Engine: 5.0l TBI
depending on how loud the clunk is it could just be normal noise from a rod end setup (would still check it out). not sure how that sliding link works that could be the cause also. maybe the sliding mechanism is not adjusted right or something. i would advise having a race shop adjust your setup, it makes a big difference. you could try switching to the stock torque arm to rule out all the other new pieces.
Car: 1983 trans am
i drove it alot today and triple checked everything again... one noise is my exhaust rattling on the body and im pretty sure the torque arm noise is normal due to the rodend and sliding link
Ragtop Man
09-12-2015 12:23 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
