Shop for ring and pinion install?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Time for that 3.73! Looking for a good shop, preferably southwest 'burbs but will drive a bit for a reputable/quality place. Thanks!
Re: Shop for ring and pinion install?
Finish line performance in naperville
yea i seen his junk rear pics, what do you want me to say? they've done tons of others with no issues. Every piece on my car or someone's I personally known has broken or blown up after a shop has touched it from motors/trans/rears/whatever all within the break in period, not being beat on etc. IMO i don't feel any 10 bolt is worth putting a dime into, besides "maybe" a diff cover. Gear swap and setup plus time to drive vehicle there etc etc puts you $500+ easily on something that is the weakest GM rear ever made. moser housing is $1000 with axles, getting a junkyard center section or an ebay $400 center that's been gone through would be stronger. I've popped 4 or 5 ten bolts so I know what it takes to break them.
Car: 92 T/A 'vert
All very true, but, a 305 with a few bolt ons, shouldn't pose much of a problem. Also, should I be looking for an aluminum drive shaft? Something about vibration and "critical" speed due to the increased RPM's of the shaft? Thanks for the input!
ls1 aluminum shaft sure. a thirdgen or lt1 shaft i would pass on. It's hilarious that people still try to charge $150 for a 20+ year old aluminum one out of a thirdgen, when you can buy a under 10 year old one from a ls1 for the same prices. I'd check out www.ls1tech.com and try around there. They are bigger in diameter and have a vibration dampener on the trans side as well as being a direct bolt in.
just ask for the pinion depth and back lash when getting gears, kind of to double check their work other than just using the marking paint.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
For the money Brandon ended up having into getting that done, fixed, and done again, he could have had a 12-bolt in his car. Who knows why it really happened. FWIW, if I was staying nitrous next year, I was either going to get the car tuned by Mike@Straightline or Harris Speed Works in Pennsylvania, so I definitely have some trust in him still
My 2.73s in my '88 broke on me one day after getting home from the track. Didn't cut anything better than a 2.2 60' all day, so its not like the rear took a ton of abuse (and it was an auto). Then a few days later, on my way to work it was making a horrid whining/howling noise (I only worked 5min away). Got to work, parked it. When I was leaving work, I put it in reverse, stopped, put it into drive, and every two feet or so CLUNK CLUNK. Had to progressively give it more and more throttle to move. I got to the end of the parking lot before the car wouldn't really move any more from gear bind. About a 1/3 of the pinion gear was sitting on the bottom of the housing along with a couple teeth off the ring gear. All that was done to the car at the time was an SLP cat-back, and a cold air intake.
I ended up replacing it with another 10-bolt, but it had LS1 brakes and I got it for like $200 On the Z, I just went straight to a 9". When I pulled the 10-bolt out, a couple teeth from the posi gears inside the diff were sitting in the bottom of the housing, but the rear still worked (the posi wouldn't work around corners though).
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
sailtexas186548
08-26-2015 03:32 PM
hectre13
08-26-2015 08:17 AM
rsrmoore
08-07-2015 08:44 PM
