Chould it be my starter?
Car: 92 firebird,79 camaro
Engine: v6 3.1.....305 V8 , 650 Holly carb,
Transmission: borg wagner t5....Posi track rear
Axle/Gears: 323
Every know and then my car doesnt turn over if i rock my car,then it turns over.So my ? Is do i need a new starter.
Axle/Gears: 323
Re: Chould it be my starter?
No its starts when its hot ,its just a random thing that happens .If i start to rock it back and fourth will im sitting in drivers seat thats what i ment...humm who knows maybe its the ignition??
thanks for your help
angie
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
What is it doing when its not starting? Do you hear a type of metallic banging noise?
When you are rocking the car back and forth...is the clutch in or out?
Tim had an intermittent problem on his car where the starter would hit the flywheel instead of engaging properly. Shimming it didn't seem to work either. It'd just be random. His was an auto though, so instead of being able to rock the car back and forth, he had to leave a ratchet with a deep 5/8" socket on it.
Car: 1997 Corvette
Yeah, I guess a little better description of what's happening. When it doesn't start....does anything happen? Does anything sound like its moving? Do the lights on the dash go out with the key all the way forward?
Axle/Gears: 323
No nothing happens i turn over key nothing no sounds ,i know my neutral safety switch is out but would that actually cause that..hummmmm for 6 bucks no problem i would be happy if that was it..
Car: 1997 Corvette
Yeah, the neutral safety switch wouldn't allow the car to crank over if it were bad.
Axle/Gears: 323
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Or the starter relay thats found behind the drivers side kick pannel. Put in a new neutral safty switch and ignition switch only to find out that it ended up being something thats free at the junkyard.
Kevin
Kevin
Axle/Gears: 323
I cant even find a juck yard in my area that has firebirds,everytime i call i end up calling 10 different yards and they all telll me no we dont have any firebirds,so i dont think it would be free for me : (...
1 Post
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Don't spend your money yet. Check the connections at the battery and tighten them if they move the slightest bit. Then go to the starter and make sure the wires are tight there. Then go the length of the wire coming from the starter to make sure it isn't burnt by the manifolds or headers.
Finally, thank me for saving you 6 bucks,
POZ
POZ
1 Post
Engine: 350, 355
Did you ever fix the problem? It helps others when you post what you did to fix it.
Axle/Gears: 323
Sorry its been awhile,and it was my neutral safty swicth....
1 Post
Engine: 350, 355
Good to know, in case MY car isnt turning over! Steve, I will try my best to make it out there! I had a great time last time.
![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
Gunner242
12-25-2015 04:49 PM
