88 iroc rear end question
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
ok, i got a wrecked iroc with a posi rear but it has 2.77 gears . ive heard from a friend that i cant swap gears in it cause its lower then 3.08 is this true?he said id need a whole diff carrier? if this is true its for sale if any you guys want it just let me know
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Re: 88 iroc rear end question
Thats true. the 2.77 is a 2 series carrier and you need a 3 series carier to install a bigger gear.
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
go to advance auto parts and go buy a gear spacer it will make it a stage 3 carrier i did the same to mine i had a 2.73 gear then went to a 4.11 and used the spacer works great.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
