Dyno Tuning near Indpls Area?? help....
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
I have a 91 rs/b4c
specs
eagle 383 rotationg assembly .060 over
gm 847 cam 236/242 at .050 with 539/557 (i think dont have card on me) lift
dart platnum iron eagle heads 64cc, 215cc
holley stealth ram intake
#34 injectors
stock throttle body
38 psi fuel pressure
3000 stall
turbo 400 trans
shift kit
stock computer
i have a ls racing mail order tune but it is very rich all around only ran a 12.80 at 112 mph. i think there is alot left in it
does anyone know of any place locally that does dyno tuning on third gens. the few i called only tune lt1 and ls1
thanks
specs
#34 injectors
stock throttle body
3000 stall
turbo 400 trans
shift kit
stock computer
thanks
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
112 is enough for 11's if you 60ft the hell out of it :-)
If its on a stock tune now I wouldnt even drive it. You will kill it and wash down the walls/rings. (unless u can verify otherwise with a wideband or scanner)
Hit the DIY PROM board here. For less than what u would pay to get it tuned u can get the stuff yourself.
That things is so pig rich at idle and lower rpm's your eyes are prolly burning, and if u have cats on it still, there done too.
Bare min would be set the injector constant to 34, put the fuel pressure back to 43.5 line off. Prolly pull 15-20% of the fuel out at lower rpms below 1600 or so and start from there.
Mail order tunes are for the most part guesses and thats all. Read the stickies we assembled on the prom board. If your willing to pay gas and food and we can work something out I will try and help you if u start learning how to.
later
Jeremy
later
Jeremy
i have tuner pro rt but i am still trying to figure out how to record a data stream. I was thinking if icould capture the data stream i could sent it to ls racing and have him improve on what i have. my tune was only $170 and it is very streetable. I have a great starting point. just want to get the fueling and ign curves closer
