new cam :)
Car: 87 gta
new cam :)
got a goody out of the donar car today. this is what the part # gets me.
211257/265 for ISKY CAMS .
# Grind No./Type RR-257/265 HYDRAULIC ROLLER Excellent performance cam with good vacuum good idle. 3.08-3.73 axle ratio. 9.5
# 1 compr. Up to 650 CFM Carb. Computer compatible. Stock converter. RPM-Range
# 1400-5600 Valve Lift - INT
# .465 EXT
# .485 Valve Lash Hot - INT
# .000 EXT
# .000 ADV Duration - INT
# 257° EXT
# 265° .050 Duration - INT
# 209° EXT
# 217° Lobe Center
# 112°
should work very well with my set up. also to compliment the cam some comp cams roller tipped rockers 1.52's.
what do you guys think? should add a little umph huh?
# .465 EXT
# .000 EXT
# 257° EXT
# 209° EXT
# 217° Lobe Center
# 112°
