Dear Friends, we are gathered here today....
To lay my beloved posi to rest. She finally found her peace after trashing one last *****.
Now, to rebuild or replace........ Hmm........ There is that lovely article posted on the front page about rebuilding/shimming 9bolts. Or there is the option of a later year 10bolt with the 11.65" PBR's. Hmm.....
What to do, what to do.....
First off, need tune. That is what I'm saving for now.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Its roughly a 1K to rebbuild a 7.5 right.... I just did mine.
9 bolts cost a little more, but ultimately it comes down to what is actually broken inside the thing... If u just need bearings and a shim its fairly cheap. U need gears or posi , ouch...
later
Jeremy
later
Jeremy
Well, it could just need to be shimmed. But if there is slack in the posi, its likely it has started tearing up teeth. I'll know when I pull the cover off to change the fluid. But it whines when going around a corner at low speeds. So I've known for a while that its on its way out.
If the gears are shot, ls1 4th gen rear for me. If not, I might look into rebuilding it according to the article. I now know where I can get the tools needed to properly measure the preload, pinion depth and other fun stuff.
Z28/ZR1
10-23-2015 01:04 PM
david068513
09-18-2015 10:36 AM
