Can't wait
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
Can't wait
Just need somebody to weld in subframes, anybody?
1 503 Sub-Frame Connectors
1 BG-Sport-3 B&G Sport Springs
1 902 Polyurethane Bushing & Chassis Grease $14.00 $14.00
1 301 Adjustable Torque Arm - 700R4/T-5 Trans.
Red
Color?: Bright Red
No Loop
Driveshaft Loop(s)?: No Loop
Poly
Front Mount Type: Polyurethane Bushing
1 982 Torque Arm Rear Mounting Hardware Kit $16.95 $16.95
1 101 Panhard Bar - Tubular with Poly Bushings $85.00 $85.00
Red
Material Type: 4130 Chrome Moly
1 983 Panhard Bar Mounting Hardware Kit $10.95 $10.95
1 201 Lower Control Arms - Tubular with Poly Bushings $110.00 $110.00
Red
Color?: Bright Red
1 981 LCA Mounting Hardware Kit $10.95 $10.95
1 923 Spohn Sway Bars Set - Solid 4140 Chrome Moly
Color?: Bright red
Now all I need are a good set of shocks
Red
Color?: Bright Red
No Loop
Poly
Red
Red
Color?: Bright Red
Color?: Bright red
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Why did you get lowering springs but not an adjustable panhard rod?
Looks like a good setup. Toss in a wonderbar too...those things are nice. Also get some poly swaybar endlinks if those Spohn bars don't come with them...world of difference with the twon things I just mentioned.
I have some LCAs that I need to install, and I have to pick up some SFCs one of these days as well.. Anyone around here have a set that I don't have to pay shipping on?
Car: 2003 Corvette
Transmission: one that has 6 speeds
Re: Can't wait
Red
Color?: Bright Red
No Loop
Poly
Red
Red
Color?: Bright Red
Color?: Bright red
Red
Color?: Bright Red
No Loop
Poly
Red
Red
Color?: Bright Red
Color?: Bright red
PM sent and just ordered the Bilstein shocks, should get in by the 30th Now need to change the panhard to adjustable and I'm set.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Re: Can't wait
Originally posted by Winger4800
I can weld them for you if you still need them to be.....
Kevin
gixxer92
04-12-2022 12:09 AM
