1991 Chevrolet Camaro Z28 6.7 SLP T-Ram Injection $9398.00
1991 Chevrolet Camaro Z28 6.7 SLP T-Ram Injection $9398.00. Race Ready and Street Legal, e-mail me at ReevesSuperZ@cs.com Serious Inquiries Only!
Michael Reeves
1991 Camaro Z28 6.7 SLP T-Ram Injection
Mods include: Lunati 408ci short block ***'y w/Lunati super bracket rotating ***'y internally balanced w/pro mod rods and Lunati race prepped block w/steel caps, SLP T Ram intake ***'y, 1050cfm 58mm TPIS throttle body, Holley adjustable fuel regulator, Holley 255 lph. fuel pump, Motorsport 24lb. injectors, Mike's custom dual ram air, TFS Twisted Wedge heads/fully ported, Comp Cams double valve springs w/titanium retainers, Crane 1.6 gold race rockers, Comp Cams 4130 custom pushrods, Comp Cams hyd. roller lifters, B & B Performance valve covers, Comp Cams Extreme Energy hyd. roller 236/242 duration .558/.570 lift custom ground @ 112 deg. lobe sep. w/1.050 reduced base circle, Pro Form mini starter, SFI approved flex plate, Formato's Faster Prom, Crane Hi-6 ignition w/PS-91 coil, SLP 1 3/4 headers w/Jet Hot coating, 3" high flow cat, Flowmaster force two cat-back system, Auto Specialties street crank Pulley, 6 1/4 Fluid Dampener, 4L60 Trans w/H.O. kit incl. Rabestos Blue Plate clutches plus: Corvette servo, .500 boost valve, .296 int/rev boost valve, and TransGo 2&3 Reprogramming Kit, Torco torque converter 3100 stall w/lock up, Summers Brothers 12 Bolt ***'y w/Auburn Pro carrier, Richmond 3.73 street gears, Energy Suspension bushings, motor mounts, and trans mount, Hotchkis lower trailing arms & panhard rod, Air Lift air bag in the right coil spring @ 17 psi., Jegster bolt in frame connectors & drive shaft safety loop, Crane Cams vacuum assist canister, Moroso Blue Max sleeved plug wires, Bosch platinum plugs, Robertshaw 160 deg. thermostat, Edelbrock hi-flow alum. water pump, Auto Meter Pro-Comp 2 tach, Mickey Tompson ET Street 16x11.5" tires to hook it up at the track, Presario laptop w/DataMaster Software to data log, and CoverCraft Noah Car cover for the winter.
Member of ColoradoF-body.com
Michael Reeves
1 Post
Car: 1992 B4C 1LE
wasnt there an older guy selling this at the superchevy show swap meet?
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Linson
08-21-2015 02:12 PM
