Anyone know where to get these hose clamps locally?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Gates Thermoplastic clamps?
These things are badass.
http://www.gates.com/brochure.cfm?br...ocation_id=546
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Anyone know where to get these hose clamps locally?
I clicked on the where to buy. Put my zipcode and a 70 mile radius. It showed Motor parts distributor's in Modesto. One of my part suppliers at the shop. You can either do the same. Or I can check with them tomorrow to see if they indeed actually do offer those. Let me know.
Car: '02 Z06
Engine: L33 5.7
Ya can you do that for me? I need two for the top radiator hose and one for the lower hose to water pump. I am not going to worry about the lower radiator hose side as that sits so low and out of the way it would be difficult to even get a proper heat gun down there to seal it shut.
I think those 'clamps' look so much cleaner and with a nice coolant pipe instead of rubber hose my engine bay will be that more more complimented!
1 Post
Car: 92 Z28
Engine: Boosted LSX
The gates look good but what if you need to remove it?
Cool video of them http://www.youtube.com/watch?v=4O91YqHbp8c
why not some nice billet pieces? http://www.prolockhoseclamps.com/
http://www.summitracing.com/search/B.../?autoview=SKU
Car: '02 Z06
Engine: L33 5.7
Cut it to remove it, apply new ones How often do you really remove hoses anyways? I have not removed one since my last radiator job.
Engine: gone
Transmission: gone
Axle/Gears: gone
I will look into it for you
Engine: gone
Transmission: gone
Axle/Gears: gone
Ok called my source. They used to carry them all. They never moved any after promoting them and all. And got rid of the whole line. So it's a no go on my part. Check your area Trav. You have connections in oreilly still too right? You should be able to go to gates direct via Oreilly and order what you need. If you cant do that. I can go through my oreilly and see if they can come up with anything.
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
O'reilly's can get them usually same or next day. least up here in the seattle area. ive worked there for years and can usually get a majority of hard to find, or odds and end parts.
Car: '02 Z06
Engine: L33 5.7
my local store I retired from is too dumb to locate the gates catalog to even find me a part number.
88SS6SPEED
11-11-2015 07:05 AM
