Electric water pump install.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I don't know why I didnt do this sooner. Awesome 'mod'.
Wired up easy, comes on with ignition switch. When the motor was running temperature and the key was turned on, you can hear the coolant flowing through the motor and with the fans on, the needle on the temperature gauge can be seen dropping. Its nice!
Car: '02 Z06
Engine: L33 5.7
Re: Electric water pump install.
Not the best pictures, the shadows made it hard for my phone/camera. I will try to get some better ones later. Until then, selfish promotion of engine bay pics.
Engine: gone
Transmission: gone
Axle/Gears: gone
oh so that is what you needed the summit bucks for
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Mezeire, Moroso, Summit? I'm still running an Edelbrock mechanical/aluminum with no issues.
When's your next track visit? Hoping for a 10.99??
Car: '02 Z06
Engine: L33 5.7
no issues with my mechanical either. why not lose that belt friction though. plus its lighter then an aluminum pump. in between passes the cooling of the motor is way quicker as well
Engine: gone
Transmission: gone
Axle/Gears: gone
down for racing? hopefully a few more weeks and i'll be going out and hopefully improving on my last track day..blah!
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Are you still running a thermostat? If so why?
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Which brand of electric water pump?
Any changes to the Serpentine belt?
Car: '89 GTA
I have heard both ways, but I got the info below from another forum:
Also, do you run E85 on that car, or was that the 4th gen? I know you shouldn't run E85 any cooler than 170 degrees. It is like menthanol and has to be almost hot to run correctly, no? Just some food for thought.
No thermostat but you do need to slow the flow down so that it remains in the block long enough to absorb the heat and stay in the rad long enough to dissipate the heat. That's where a restrictor comes into play. Moroso sells a kit with different sizes but 3/4" is a good starting point.
In the pits during cooldown between rounds, using an electric water pump and a thermostat to cool the engine doesn't always work. As the coolant temp decreases, the thermostat closes and coolant flow stops going through the rad. A simple fix is to drill a couple of small holes around the thermostat which will still allow some flow through the rad even if the thermostat is closed.
Car: '02 Z06
Engine: L33 5.7
And for the other posts, I guess I will be removing a thermostat
Forgive my noobness but why did you go electric?
Engine: gone
Transmission: gone
Axle/Gears: gone
mechanical water pumps create drag and when your trying to get every possible HP it counts. But also in between runs an electric pump can be ran without the engine running to cool the engine, cooler engine=more power, and less wear on mechanical parts.
Car: '02 Z06
Engine: L33 5.7
Jesse- What is your thought on having or not having a thermostat?
On another note; I had all my windows tinted 5%. The hatch, side windows and T Tops.
looking killer. Just waiting impatiently for my carpet to arrive!
Engine: gone
Transmission: gone
Axle/Gears: gone
he has a point too. you dont wanna be running too cold. too cold of an engine burns fuel ineffciently, you wanna have a hot combustion chamber. Should have put the water pump on a switch so you can have it turned off for awhile, then turn it on. But if the switch is on all the time it'll operate normal.
Transmission: T700
Can anyone recommend a brand of reliable electric water pumps?
Car: '02 Z06
Engine: L33 5.7
I could wire up my water pump relay to my fan trigger as well which is monitored by holley HP EFI. on at 180 off at 160..
Engine: gone
Transmission: gone
Axle/Gears: gone
That's an idea I think you might want a restrictor in there at least if your not going to to have a thermostat
i've always ran one
...then you just got done driving? i'm not sure of the question
evilstuie
01-09-2020 08:29 PM
Chuck84TA
07-15-2016 09:05 PM
