What kind of project you got going on with your third gen right now?
#301
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: What kind of project you got going on with your third gen right now?
It is noob initiation sorry. You get to do the next group in two years!
#303
Car: 1992 Camaro RS
Engine: 305 TBI L03
the little gold things are the "teeth" im talking about
#304
Car: 1992 Camaro RS
Engine: 305 TBI L03
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Mandatory donuts session. No backing down last minute.
#306
Engine: gone
Transmission: gone
Axle/Gears: gone
About the gold teethe. I'd imagine it might not require all of them. But again that style I have not messed with too much. Hopefully someone else can chime in.
#307
Car: 1992 Camaro RS
Engine: 305 TBI L03
Hahaha i got old *** tires tho..
& yeah I hope someone chimes in about the teeth, I don't know if that's normal or not.
#308
Engine: gone
Transmission: gone
Axle/Gears: gone
FYI. Bring some money for new tires. Because once Trav, Copchaser, and I. Get done doing the donuts you'll need some. Les Schwab will come to the track and install
#309
Car: 82 Trans Am, 68 El Co, 84 K5
Engine: Carb 350, Carb 327, 6.2 Diesel
Transmission: Borg-Warner T10, TH-350, 700R4
Axle/Gears: 3.23, stock 10 bolt, 3.73
Hey guys. its bin a long time since i last logged in. well i just graduated from UTI still got the black trans am but i got a new project. its a 89 formula, i just finished building the bottom end now its just heads cam intake system and exhaust.
#310
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hey 92RS sorry I never noticed an update to this thread. It IS normal to be missing teeth like that. You can try bending them a little bit to make a better pressure contact with the circuit board.
#311
Engine: gone
Transmission: gone
Axle/Gears: gone
Hey Jazz good to see you are around still! You doing a stock build or performance build? Pics?
#312
Finally got the right speedo drive and driven gears, need to get them. Steering shaft is all straightened out, still putting together parts for a flaming river setup. And I still need to get the damn thing tuned, man time flies.
Will
Will
#313
its on the road but i just need to break in the bottom end and give it time for the rings to seat. next more parts to increase intake and exhaust flow. then a new cam, roller rockers and hopefully some boost. just enough to get me above 500 hp
#314
heres a pick of the front. the guy i bought the car from had cut the front bumper cover for the inter-cooler. and i need to get new rims and ditch the wheel spacers.
#315
Car: '02 Z06
Engine: L33 5.7
Just get out on the street and drive it hard, the cylinder pressures will seat those rings real quick
#316
Engine: gone
Transmission: gone
Axle/Gears: gone
Dang nice work Jazz! a freshly machined block is a beauty of a sight!
Fast355
12-02-2016 06:33 PM
ambainb
04-25-2016 09:21 PM
