What kind of project you got going on with your third gen right now?
#251
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: What kind of project you got going on with your third gen right now?
Are you guys not running boot protectors? I ran them on the bird, some touching the headers and never had any problems.
#253
Engine: gone
Transmission: gone
Axle/Gears: gone
different plugs. his plug runs a gasket on the plug. your's don't. Remember me calling his plug #'s out the other day when we were hanging out? haha. I should be cross referencing #'s for him right now instead of trolling the board.
#254
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
On a side note, I ordered new plug wires today. Still Livewires from DUI. This time they will be routed underneath the headers as opposed to bringing them over the valve covers. Should be here by the middle of the week next week. So next Saturday I can update the results.
#255
Engine: gone
Transmission: gone
Axle/Gears: gone
working on it!
update:
striking out!!!
update:
striking out!!!
#256
Engine: gone
Transmission: gone
Axle/Gears: gone
ok i messaged you. RC12YC crosses to accel shorty plug 416ss summit # ACC-416SS
#257
Thanks sir.. I will look into it.. 40 bucks for 4 plugs??? Is there a smiley with a middle finger
#261
I kno that, I wanna flip off Accel
#263
Update: Its fixed!!!!! Champion plugs have been my problem the ENTIRE time. I got my new plug wires and installed those to no avail. I removed the Champion plugs, did a weeks worth of research on plugs and made some calls. Finally this morning I got a call back from NGK who recommended the BKR6E plug. So I went and grabbed a set of those and slapped those bit__es in. The car started on first crank, ran super smooth, revs with no problem or hesitation, idles like it should... ITS A DONE DEAL. I gotta get my exhaust re attached and get him tuned and its GO TIME!!!!
#264
Engine: gone
Transmission: gone
Axle/Gears: gone
#265
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
New front ball joints, poly control arm bushings, and Hotchkis springs. If you order them for your car and you get hotchkis 1903, 1903f, or 1903r there wrong! Those are for 93-98 cars. 82-92 need 1902, 1902f, or 1902r to work properly. Just an fyi.
Put in a 4th gen rearend and am waiting to the finishing parts to complete it. The founders pan hard rod is awesome! I orderd the on car adjustable with poly bushings.
#266
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
#267
Engine: gone
Transmission: gone
Axle/Gears: gone
So we gotta track day GTG coming up in April that is 2 months away. What does everyone have to get done on the car before that day so we can have as many thirdgen's tearing up the pavement at Sacramento raceway?!?! Even if your not racing. our last GTG at the racetrack had a pretty good sized turnout. Nearly 20 cars. Would love to see nearly 30 for this one.
what you got going on with your car right now that is stopping it from being at the track on april 14th 2012? (cali only)
#268
Well ill be there but wont run. Going through my suspension now and until im done won't run the car. Still don't have the headers or wideband on .
Under you should drive my car on the current tune(off the track )think you'll be impressed and would like some other feedback
#271
Engine: 383/LGX
I just moved, once I get settled I'll start working on the bird again. Hopefully I'll get it running in a couple months.
#272
Engine: gone
Transmission: gone
Axle/Gears: gone
it'll be nice to not be the only TBI guy like most times...
it'll all happen when it happens..but more than likely you'd be coming to the GTG right?
#273
Engine: 383/LGX
I'll be at the gtg thirdgen or not
#274
That works for me!
Get that bastard done man! I told you I was willing to come help. Lets team up on this thing. The birds need more representation!! haha
#275
Engine: gone
Transmission: gone
Axle/Gears: gone
just got an edelbrock victor series aluminum water pump going to install. my current pump has 70k and it was a cheap cardone new pump and I dont trust it. So therefore I am doing a lil preventive maintenace. I picked up this eddy pump for 100.00 bucks new so it'll be lighter, high flow, heavy duting bearings. And I wont have to worry about the pump going out anytime soon, hopefully.
#277
Car: 1992 Camaro RS
Engine: 305 TBI L03
I'm trying to change my gauge cluster for a z28 one but I can't disconnect the stupid old one is there some kind of trick or am I just retarded?
#278
Engine: gone
Transmission: gone
Axle/Gears: gone
Umm those clusters are so easy to change. Just take the front fascia off. and any other bolts you see in front and pull it out. the connectors are stationary behind it and it just slips into place.
#279
Car: 1992 Camaro RS
Engine: 305 TBI L03
Haha I guess im just retarded lol. Do you just pull it out after you take off the bolts? Like does it just slip out?
#280
Car: 1992 Camaro RS
Engine: 305 TBI L03
There's some article on here that I was using but it said to shove my hand behind the speedometer & disconnect it but there's no room up there for a hand lol
#281
Engine: gone
Transmission: gone
Axle/Gears: gone
on an electronic speedometer like your car should have their is no cable. The one I pulled out at the junkyard just pulled right out after i removed all the bolts.
#282
Car: 1987 IROC-Z
Engine: 5.7L
Current Project: Lower intake manifold gaskets are blown...So far I have the hood off! lol. Any tips/suggestions?, going to use Chilton & Haynes manuals to do this. Hoping to get it done soon but there isn't enough time lately. Ugh!
#283
Engine: gone
Transmission: gone
Axle/Gears: gone
DUDE the gtg is on april 14th you need to make time and get that knocked out and be at the GTG
#284
Car: 1987 IROC-Z
Engine: 5.7L
theres no way i could make that, my interior is completely taken apart, rims need painting, Car needs painting, the list is never ending >.< I work that day anyway...
But i hope to get the car Done by the end of the month. we'll see how deliveries go of items I need.
#286
Car: 1987 IROC-Z
Engine: 5.7L
You're right, i should just strip the car to bare metal. then itll be like a silver paint job! right?!
#287
Engine: gone
Transmission: gone
Axle/Gears: gone
Very dissappointing man!
#288
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Did you see last years pictures? I bet you could point mine out!
#289
Car: 1992 Camaro RS
Engine: 305 TBI L03
Yeah it was hella easy lol. But the speedo & gas gauge still dont work but i got it off hawks so it shouldnt be the cluster, are those little connectors that you plug the cluster into supposed to have all the little gold "teeth"? Also what's infl rest mean, Cause it only turns on with my new cluster?
#290
Car: 1992 Camaro RS
Engine: 305 TBI L03
I'll try to get a picture up of the "teeth" lol.
#291
Engine: gone
Transmission: gone
Axle/Gears: gone
The gold teethe is normal...inflatable restraint is an air bag light. If it was me id pull the damn bulb out and call it good. I hate airbags. lol.
#292
Car: 1992 Camaro RS
Engine: 305 TBI L03
Lol what I meant about the teeth is that some aren't there, get me?
#293
Engine: gone
Transmission: gone
Axle/Gears: gone
I see. To be honest I have about close to no experience with your type of cluster. I found one at pick n pull one time pulled it out in 5 minutes and sold it for 140.00 bucks. So my information and knowledge is severely limited.
#294
If all goes well tonight i should have an 89 Iroc-z to FINALLY get out with you guys. I hope you guys will be willing to be patient with a noob like me. =D
#296
Car: 1992 Camaro RS
Engine: 305 TBI L03
#297
Car: 1992 Camaro RS
Engine: 305 TBI L03
#298
Car: '02 Z06
Engine: L33 5.7
92rs!, Can you post photos of your issue? Perhaps I can help.
#299
Engine: gone
Transmission: gone
Axle/Gears: gone
Just for the record. Copchaser, trav, and I. All get to do donuts in you noobs cars.its like initiation.
#300
Car: 1992 Camaro RS
Engine: 305 TBI L03
Yeah I'll get some up I'm just tryna figure out how to haha. Lol I'll let you hit donuts in my car if I can in yours!
