What kind of project you got going on with your third gen right now?
#201
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: What kind of project you got going on with your third gen right now?
well it has to run before you can smog it but im glad it's almost back on the road
#202
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
waitin on your spark plug wires mayne!
#204
Engine: gone
Transmission: gone
Axle/Gears: gone
I know man but you didnt say anything about that. you made it seem as though it is running! just gotta keep you straight
#205
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
that looks good Tim. I like that a lot.
#206
Engine: gone
Transmission: gone
Axle/Gears: gone
he put A LOT of time in that thing good job. I need to see it all finished though!
#207
Keepin the thread alive got my plug wires in tonight goin to fire her up tomorrow.
[IMG][/IMG]
[IMG][/IMG]
#208
Everything is getting done to my 86. Right now shes just a shell. Got the new doors lined up pretty good and hopefully after christmas the interior will be back in. Just waiting on window motors, sound deadener, and new carpet. Took the dash out to run the wiring harness for the power windows, as they were manual before. Shes pretty much a toolbox now.
Before the tear-down a few months ago:
I bought her for 500 bucks not running with a 305 and 700r4. I got the 305 running nice and test drove her a few times. Right before i was gonna get some plates and registered she spun a bearing, and the tear-down begun.
#210
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
I ordered some original lug nuts from Hawks a couple days ago, and I'm going this weekend to pick up a dash pad and rear hatch shocks that I found on Craigslist for $90. The pad has no cracks at all. I couldn't believe he was only asking $90 bucks!
#211
I used taylor spiro pro 8mm wires dui dizzy and accel shorty header plugs i had msd street firewires but burnt holes in em i used these taylors before and i was really pleased with them plus made in the usa makes me feel lil better.
#212
you plannin to stick with the 305 mgg?
#213
Car: 86' Iroc-Z
Engine: tpi 350 small block
Transmission: a4 :)
Axle/Gears: bone stock for now
ok so i bought an 87 iroc with 81,000 miles and runnig for $400. i recently swapped out the whole stereo system painted and cleaned up the dash re covered front seats ( still gotta do back). New head liner. As far as the motor goes, i am really just cleaning it up. Pulled the whole manifold off. and tpi system, ect and doing my best to restore them. Flushing alll systems, changing all gaskets or at least 90%. plugs n wires. removed the smog pump, and windshield washer fluid. going to takle the a/c compressor next. Stream lining my air intake and turning it into an enclosed system. Then outside not to much body work a little bondo on the roof in 2 spots about the size of a 50 cent piece. Then we will wrap the whole car in matte black vinyl. Crome out any and all visible emblems. Then lay pinstrip gloss black flames on hood wheel wells and ect. That is so far all the money i can put into this thing, but it is my baby so every extra penny i got is going into it. At least until i get my girl prego. lol
#215
http://www.youtube.com/watch?v=UUtFM7_YCsg
Its About Time Started Right Up 1 Code Came Up 32 EGR Failure
#216
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
fuel pump!!!! powerwindow motors!!!! paint!!!! and finding new guts for it maybe a tt set up for the 305 (kinda wanna blow it up) and then the 406 goes in this summer
#217
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
#218
yea hopefully i dont burn holes thro these ones i put the heat shield boots over em so hopin dont have any problems
#219
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Did some cleaning
and some painting
know what those bolts are for now?
and some painting
#221
Engine: gone
Transmission: gone
Axle/Gears: gone
terrell working on some calipers sweet! did you use the "caliper" paint or regular rattle can paint?
500 hp 383 stroker sounds awfully good over a 305 to me mgg!
#223
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I used that on my aluminum rear drums. It covers nice. Good work
#224
Well as we all kno, I have been trying to get my car figured out the last few months in between work and being a family man. Yesterday I had it running and was playing with the timing and the idle and a few diff mafs. At times the car will have vacuum, and other times it wont. It backfired a couple times, so I decided to pull my plug wires off and get set to swap in a fresh set of plugs, while inspecting the wires, I didnt notice much...on the surface. I pulled my boot protectors off of the ends that attach to the plugs and notice a small hole in plug wire number 3. Then I went to pull the protector off of number 5 and the whole boot split into two So now i know that may very well solve a lot of my problem. I cant find my cable for the camera, but I will load pics as soon as I do.
PS Happy New Year All
#225
Car: 1992 Camaro RS
Engine: 305 TBI L03
My baby's still in the shop they can't figure out why the battery keeps draining overnight haha it's been almost 2 ****** months. Can't wait to get it back I wanna put leather 4th gen seats in it if anyones got some lemme know
#226
Car: 1992 Camaro RS
Engine: 305 TBI L03
& happy new year copchaser
#227
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I can't get picks to load but I have put all new poly bushings front and rear, new power steering pressure line, new valve cover gaskets, changed all fluids, cleand and shampooed the interior, hatch repair, and the list goes on and on! LOL
#228
Engine: gone
Transmission: gone
Axle/Gears: gone
pull the negative battery cable off and put a test light between the negative post and cable end. pull fuses til you find the fuse that turns off the light. then trace everything off of that fuse. go one by one unplugging everything on that circuit you'll eventually get it.
#229
Car: 1992 Camaro RS
Engine: 305 TBI L03
#231
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
#232
as promised... plug wire number 3
plug wire number 5
plug wire number 5
#233
my plug wires looked like your first pic there hopefully that solves your problem for you
#234
we are also runnin the same dizzy as i remember hopefully thats not wats causing are wires to do this
#235
I doubt it. The dizzy had just been tuned up by them and their wires im sure are designed to handle the power. Its the heat around the headers that are worrying me. I had high heat tape, AND boot protectors on and this still happened... smh
#236
Engine: gone
Transmission: gone
Axle/Gears: gone
deffinately too much heat around there. i remember we were just talking about those wires
#237
Guess ill add.
got LS1 brakes in the front now happy with it. balljoints suck to get off haha. Ive got good tips to those who are going to do it though. New balljoints as well.
Hooker headers go on next month with the wideband, thank god. Thennnnn...nitrous..boom
#238
Im bout to do a set of LS1s on wifeys car. I know its a basic swap, but is there anything hidden I need to know before I begin the swap?
#239
yea i was lookin to buy the liverwires but jus settled with the taylors
#240
The lives are like $100. How much were the Taylors? I want 10.5mm ones.
#241
Car: 1988 pontiac firebird 2.8 v6 base
Engine: 2.8 v6 173
Transmission: automatic
Axle/Gears: stock
im just waiting to save up some money so i can get a cai,headers and true dual exhaust,and a chip sometime in febuary for my 88er with a 2.8 lol and i just finished painting it in november.cant wait to drive it this summer! and in the long term i wanna get torque thrust M rims in chrome,and that bauer brake set on the hawks site,and a few more goodies
#243
yea the 8mm taylors are cheap like 60 buck but i think the 10.4 mm the cheapest i seen of them is like 175 i think
#244
Yea Il prob just stick with the livewires. I like them alot, plus they come sleeved to protect them. Its the boots i need to protect a lil better.
#245
Engine: gone
Transmission: gone
Axle/Gears: gone
you can run a shorter plug which will help boot to header clearance
#246
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
accell makes shorties but ive never ran them
#247
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
hay Travis, I like your new wheels. What are they?
#250
i was using the accel shorties and you could see the spark travel thru the plug jus switched to ngk ur55 they are shorties and the plugs dont glow anymore and thats all i changed but you got the different heads so might not be able to run em idk
