My car has no balls
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
My car has no *****
I need to find a new (used) engine/tranny for my car is running but everytime i'm about to hit a hill or i just wanna go fast it takes forver to pick up i mean accelerate if anyone an i mean ANYONE knows where i can get a F U C K I N G awsome deal let me know please!!!!! PLEASE I'M CARLESS
Car: 83 z28/ 82 trans am
Engine: stock? 305 w/crossfire
Axle/Gears: 3.73/stock 2.98?
Re: My car has no *****
There are a fer questions you should ask before throwing an engine/trans at your car. mainly can what you got be fixed for less time, money, or work then replacing?
did it start not having any power all the sudden or over time?
is the trans slipping?
can you get power by manually shifting?
is it even the engine or a plugged exhaust?
If the engine is toast do you want to upgrade? pick-n-pull has a lot of 350s
If it is knocking, slipping, or spewing smoke then you might need some parts
Just some thoughts, you might want to have a shop look at it before dumping money. I would hate to see you change the engine and trans only to find that your map sensor or tps is bad.
I do have a 305 block, the #'s look up to be a '78 I think, but there is a rebuilder sticker on the side.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Get a second opinion from an experienced mechanic. And I mean someone who knows how to diagnose the problem.
Engine: gone
Transmission: gone
Axle/Gears: gone
deffinately have a shop check it out. and grow a pair! haha.
Car: 1989 RS Camaro
did it start not having any power all the sudden or over time? **Poured a whole can of sea foam in the throttle body while ago
is the trans slipping?** yes i think, theres knocking from cylinder 7
can you get power by manually shifting? ** Nope i floor it but pick up is sluggish
is it even the engine or a plugged exhaust? **Uh it smokes when i start it
Just some thoughts, you might want to have a shop look at it before dumping money. I would hate to see you change the engine and trans only to find that your map sensor or tps is bad. **Tps does need to be replaced, map i'll check it out. pink n pull how much for an engine ??
Car: 02 Chevy Impala
Engine: 3.8L V6
Axle/Gears: FWD
Get a compression test. I have a 305 RS too with auto tranny. Major difference with a major full complete tuneup! Also helped tons with a cat back 3" exhaust kit, mandrell bent is the best! Got it off Summit, cost around $350, edlebrock, sounds sweet though and help a lot. Do some headers too, I have yet to do those though. But first start with a compression test and a complete diag.
Linson
08-21-2015 02:12 PM
NBrehm
08-05-2015 07:57 PM
