throttle valve cable for a 350 tpi
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
Do anyone have one, my old one is no good and i can not find a new one at a local parts store
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: throttle valve cable for a 350 tpi
i have a damn near new one that im not using because I yanked it with my 700r4 that im no longer using.
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Call Bowtie Overdrives 760-947-5240, 17359 Darwin Ave Unit C
Hesperia, CA 92345
Hesperia, CA 92345
Never mind thanks anyway
Car: '02 Z06
Engine: L33 5.7
I can produce pics.. I pulled it because it was starting to slip into third under hard acceleration, but my engine is pumping out quite a bit of power. see sig.
I could honestly say this trans would function fine behind a stock or mild tpi.
I will let it go dirt cheap for you. pretty much whatever.. I am the nicest tgo nor cal seller ever.
pm me if interested. ill even throw in the tv cable
when I bought it, i thad about 500 miles on it, i probably put another 2k on it, and it was built to a 500hp spec..
Sanjay
08-12-2015 03:41 PM
1990, 350, 700r4, 92, accelerator, broke, cable, camaro, iroc, megasquirt, mn12, throttle, tpi, transmission, valve
