Northern California Discussion board for Northern and Central California.
TBI to Carb
Old 09-25-2008 | 06:48 PM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
TBI to Carb
Guys im switching out for a carb and i was going to use my serp belt system just get the delete pullys any way i was going to put a flex lite fan on the water pump instead of using my electric fan do i need a shroud for the fan or not? and will it make a difference in cooling temp?
Old 09-25-2008 | 08:24 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: TBI to Carb
What the purpose for this fan setup? What are you trying to do bro?
Old 09-25-2008 | 08:33 PM
kahless's Avatar
Re: TBI to Carb
I dont want to use my electric fan anymore so i was going with a flex lite fan and use a 4 inch spacer and slap it on the water pump pulley. I am changing my car to carb and gettin rid of all the smog stuff so i was looking at another way to keep the car cool besides using a electric fan. I am using the serp belt set up and using delete pulleys for my ac and air pump so i was wondering about using a old school fan set up.
Old 09-25-2008 | 10:42 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: TBI to Carb
I know this isn't what you wanted to hear, but why the hell would you want to do that? Belt driven fans are outdated, old school, hurt power, hurt mileage, and flat out don't work as well. Even the stock single electric fans like the one I have and the one you probably have are better. There's a reason GM as well as every other car maker in existence switched to electric fans back in the 80s and never looked back.
Old 09-25-2008 | 10:50 PM
kahless's Avatar
Re: TBI to Carb
LOL i just want to go simple.
Old 09-25-2008 | 10:57 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Re: TBI to Carb
Like darkshot said, im not trying to hurt your feelings or anything like that but you should just keep what you got (electric fan) because it looks WAY better and is WAY more efficient that with a belt driven fan. plus i doubt they mad a fan shroud for our car. Im pretty sure you can make one but good luck with that
just stay with what you got and use the money for something else dude.
Old 09-25-2008 | 11:42 PM
kahless's Avatar
Re: TBI to Carb
If i remove the ecm computer the electric fan wont work right? that is why i was going to go with the old set up. I couldnt find anything about this posted so thats why i asked.
Old 09-26-2008 | 12:03 AM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: TBI to Carb
You can buy a stand alone fan controller for about 40$ just go to Kregin or AutoZone, it wires in and you can turn on and off the fans at whatever temp you want. That is what I am running; fans turn on at 180, and off at 160. Works great and is cheap, takes bout 30-45 min to wire in.
Just make sure you get the better one that is rated at 20 amps, and has a ajustable temp switch.
Old 09-26-2008 | 12:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TBI to Carb
The single-fan TBI setup is controlled by the fan switch in the passenger side head. The computer has nothing to do with it.
Old 09-26-2008 | 10:37 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: TBI to Carb
ECM has absolutely nothing to do with the TBI based single electric fan setup.
And by the way - you said you want to "go simple". It doesn't get any more "simple" than leaving your setup just the way it is.
Old 11-13-2008 | 12:53 AM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
Re: TBI to Carb
yea dude keep electric, you could make it real easy by just togling the fans take the power wire the batery ground it off and put the toggle in the car there ya go turn the fans on turn the car on and it will keep the at like 190 i did that to my car and it works just fine. keep her simple bro
Old 11-13-2008 | 02:17 AM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
Re: TBI to Carb
yeah thats so true just go buy a hyper~tech cooling fan switch..to replace your stock one. runs much cooler. thats what i did...good luck
Old 11-13-2008 | 05:44 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: TBI to Carb
Also you won't be able to smog your car with a carb on it.
Old 11-14-2008 | 04:13 AM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Re: TBI to Carb
I am actually Kahless' neighbor and am helping largely with this project. I would like to use one of those stand alone temperature switches for his fans, however i cannot find them in my local part store. If you guys have a part number for either Kragen or maybe even Summit Racing that would help a lot. Thank you. Oh, and the smog thing, in the county we live in up here they only require smog when you first purchase or sell a vehicle. Once you pass the inital, you are good to go.
Old 11-15-2008 | 05:18 AM
fryer1979's Avatar
Engine: 350; none
Re: TBI to Carb
Nevermind guys, I found the thermostatic switches, thanks for the idea.
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
db057
04-28-2019 08:45 AM
Wylecoyote08
09-08-2015 09:26 AM
rjcme
09-05-2015 02:23 PM
Billy Decker
09-04-2015 04:46 PM
