Northern California Discussion board for Northern and Central California.
My new CAI
Old 10-20-2007, 01:54 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
My new CAI
HERES a crappy vid. I'll try and get a better one.
Old 10-20-2007, 08:59 AM
TGO - 10 Year Member
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: My new CAI
So let's hear the details copycat.
A few of the parts look slightly different, nice bigger K&N you added.
Which model Procharger?
2 or 3 core intercooler?
Any install issues?
Any other mods to support it?
Tuning?
Old 10-20-2007, 01:39 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Re: My new CAI
Sweet, so any problems or leaks or anything? Have you driven it yet?
That is a big 3.5" Airaid cone filter and 3.5" hard inlet pipe that I made. Much better than the small filter and restrictive adapter it came with.
Old 10-20-2007, 02:03 PM
Car: '89 GTA
Re: My new CAI
Something in the back of my mind told me it was yours from when I read you sold it on 3GO.
I guess that answers my questions.
So it's the older P600B model that taps into the oil pan with 2-core intercooler?
What psi/pulley size? Did you hook it up $ wise?
Old 10-20-2007, 06:05 PM
kairles's Avatar
Engine: 383/LGX
Re: My new CAI
that was the first start, I wanna get the fuel pump changed before I drive it around. I got both 9psi and 12psi pulley, I running the 12psi pulley. no leaks or problems from what I can tell. the oil drain was a PIA. I ended up getting another fitting and hose. should work but I plan on changing it. it kinda has to climb alittle near the motor mount.
I got a good deal on it, he even came down and I helped him install it.
Old 10-20-2007, 06:28 PM
Car: '89 GTA
Re: My new CAI
Is the pulley they claim gives 12psi, the 4"? It should be marked. Will depend on your mods what you actually see.
I see the FMU in the back. What're you doing for fuel and tuning? Stock injectors?
Old 10-20-2007, 07:18 PM
Axle/Gears: 3.73:1
Re: My new CAI
Ah ok, I know when I left we just had the 90* fitting in the pan and that was it. I figured you might have to find a 45* barb or something to make it work right. Let me know if you can't get something to work. You definitely want it to go downhill the whole way to drain properly.
I got what I wanted for it, and I did drive down and help install it for two days, though it still didn't get finished.. kept running into snags. Ah well. It looks like he got it finished up nicely.
It's not marked, and it's smaller than 4" since the P600B doesn't have the same step up ratio as the self contained models. I bet he could see 10psi on the gauge depending how high he revs it and assuming no belt slip.
Old 10-21-2007, 12:02 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: My new CAI
It definitely "sucks" more than your last one
Old 10-22-2007, 04:18 PM
TMoNeE's Avatar
Car: 87 Z28
Re: My new CAI
I have a man crush on Jeremy, just so you all know.
We're gonna be at the Nug for New Years, dunno what you are up to but ill give you a call.
Nice work on the install guys, looks good, will check the vid when I get home
crazyjoe
01-07-2003 09:11 PM
Zepher
05-15-2002 09:48 PM
SillyWabbit
11-17-2001 10:55 PM
Zepher
11-15-2001 11:51 PM
3.1EyeCandy
08-29-2001 09:43 PM
Quick Reply: My new CAI
