f1r blown 383 91 camaro
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
not my car but found this on ls1tech.com this car is wicked.
Heres my dyno experience last week, the car is a 91 camaro RS with a 383 stroker with a callies crank, manley rods, JE pistons, all comp cams valve hardware, solid roller (262/272 .631 lift 114lsa) AFR 210CC CNC'd heads, SCE copper head gaskets, a victor JR intake, carb shob blow through holley 950HP carb, a Cog drive F1-R procharger, a bunch of 1-off custom fabricated crap to make the cog drive function on the street......custom fabricated tubing, FMIC, Snow methanol injection.....well alot of stuff......motor is made to rev and make power clean through 7500rpm, and we were getting ignition breakup at above 6500rpm......so we only got to 20psi (blower doesnt hit max output until 7500).....all the long block machine work and assembly was done by Golens Engine service out here in NE.
http://video.ls1tech.com/video/313ae...08012f1386.htm
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: f1r blown 383 91 camaro
i believe that guy is on this forum as well.. we talked/wrote about valvetrain and high revs..
1 Post
Car: 92 Z28
Engine: Boosted LSX
toronto formula
11-10-2015 06:17 AM
