I PASSED
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I PASSED
the Smog Check Technician Licensing Examination
Number Possible: 100
Number Correct Needed to Pass:69
Number Correct: 80
now I need to find a job as a smog tech
Number Correct: 80
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Number Correct: 80
Number Correct: 80
CONGRATS!!!!!!!!!!!!
Good job and good luck on the job hunting.
Car: 2006 yamaha r1 50th anniversary
Engine: 1.0 ;)
congrats!!!!!!!!!! yeah smog our rides!! lol no i can get the cam i want 242/242-615-615 on a 110 lobe seperation!!! j/k but congrats again
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Congrats Terrell, good luck job hunting. Make sure and let us know where you get a job so I can bring my car there.
Engine: 383/LGX
Originally Posted by JesasaurusRex
youll smog my ride...or else
I let you guys/girls know where I work when I get a job
Engine: 383/LGX
Originally Posted by porkyzilla
sweet work test only that way you dont have to do actual work
Car: 07 Silverado
...can you disprove that you did not say that you will make my car pass smog if i give you a bj
That's hella funny.
Smog your mom's car, right, you know it's your car, at least for now while the thirdgen is down.
That's hella funny.
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
so maybe you can help me figure somethin out
car passed the HC and CO part of the test but failed the NO??? i learned the other 2 abbreviations in high school but dont remember NO in PPM
well anyway results are
ave. @15mph 237 and mea. 1707 max is 767
ave. @25mph 199 and mea. 1647 max is 706
thank you for any help you can give me
and congrates on passing your test
Engine: 383/LGX
NOx is oxides of nitrogen. NOx is created when combustion temps exceed 2500*
with NOx being that high you could have more than 1 problem could be a lean condition, timing, EGR malfunction, CAT, etc.
post up the HC,CO, O2, CO2 readings, also was the car at operating temp how often is the car driven
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
very first thing to check on a nox failure is egr system, meaning making sure the egr valve is getting vaccum, ie egr control solenoid, vacuum line, you can check to see if the diaphram is ruptured in the egr valve, there is alot to diagnosing a failure but if you want a "band-aid" just put a LARGE cat on will pass but not the next 2 years lol
@15mph 12.89 2.61 ave.31 meas.88 / ave. .10meas. 10/ave 237 mea1707
@25mph 12.89 2.70 20 58 .09 .02 199 1647
B4 taking the car in i took it for a hell ride to heat things up .ive heard its best to have the cats nice and hot. the car is my everyday driver.
the cats are probley about a year old. high flo duel cats from catco
it also failed cuz the guy said there was no timing mark on the balancer havent checked for that yet
thanks for the help guys
Engine: 383/LGX
first start by checking the timing just incase, then check EGR operation. the CAT seems to be working, usually you want the CO2 to be in the range of 13.5-15%. CO2 is kinda like a cat efficiency monitor.
OH! high compression can also result in high NOx
darwinprice
17
10-11-2015 11:51 PM
