Northern California Discussion board for Northern and Central California.
I cant believe it...
Old 09-10-2005, 12:13 AM
  #101
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
the v8 swap wont be until i find a better daily driver, and i get the money to do it, which hopefully will be a year down the road, mean while im hoping to paint the car, even if it is just a maaco quick job.
Old 09-10-2005, 12:30 AM
  #102
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Well, nothing wrong with a macco quick paint job, just don't waste time and money on a 2.5" exhaust, I don't care how long the V8 swap is away, just doesn't make any sense. If you don't have the money for a 3" system then don't do anything until you do have some money saved up, that's just my
Old 09-10-2005, 12:33 AM
  #103
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
2.5" exhaust is for V6 Gremlins
Proud member of the 3" club because, size matters
Old 09-10-2005, 12:35 AM
  #104
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
a new cat would more then likely come before a new exaust, while i had the oil pan out, i droped the hole exasut and checked for any rust holes and such and i didnt find any, although i do have oil leaking from somewhere, i thinking i need to retoque the oil pan bolts.
Old 09-10-2005, 12:43 AM
  #105
Car: 07 Silverado
Oil leaking from the pan, that sucks, hope you don't have to drop that again and reseal it, that would really suck a**. Good luck.
Old 09-10-2005, 12:46 AM
  #106
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
If I was you and had to reseal the pan again, I would just pull the whole motor / trans and take a p!ss on it.
Old 09-10-2005, 08:29 PM
  #107
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: plugging cat...get a vacuum gauge, hook to intake vaccum.
Note idle reading, sea level (Hanford is close enough) shuold get 18-20in/hg. (all in park)
Rev engine to 3000 RPMs and hold it, note reading, anything lower than initial shows exhaust restriction, more than 2in/hg lower shows plugging/plugged exhaust. You can also check via backpressure if you have a 0-15 (like TBI) pressure gauge, but vacuum is easier, IMO.
I don't see how a clogged fuel filter could cause poor milage. Bad carb, yes.
Old 09-10-2005, 10:30 PM
  #108
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
i just took a look at your post again and just started laughing like all hell broke loose
8mike9,
Ill do that as soon as i can thanks for the input
Old 09-12-2005, 03:16 PM
  #109
Car: 07 Silverado
Same goes for that exhaust system, go 3".
Old 09-13-2005, 10:42 PM
  #110
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
wont a 3inch exast just kill the motor (not enough Backpressure) for this v6? yea i know i dont got much of a performance (drag) car but still im thinking 3 inch is a bit much IMO
Old 09-13-2005, 10:47 PM
  #111
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
back pressure is bad! BAD BAD BAD!!! the correct term is scavenging, that is what you want, never do you want backpressure.
3" is fine!
Old 09-13-2005, 10:50 PM
  #112
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
thanks for the info, i thought you needed Some, not a lot of back pressure, you learn stuff everyday thanks oh btw, Did you get pulled over for that burn out?
Old 09-13-2005, 11:10 PM
  #113
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
heck no i drove away fast
Old 09-13-2005, 11:11 PM
  #114
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
lol, did the cop even light up his lights? or were you gone before he figured out what happened?
Old 09-14-2005, 03:35 AM
  #115
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
3.4 swap
go get a used relatively low mileage long block for a couple hundred bucks
pull your motor out
put all the stuff from your motor onto the long block, drop the 3.4 in
done
easy as that
they have a decent kick as far as v6's go, still good on gas mileage, and it won't hurt your wallet to do the swap... Not to mention it's easy as all hell for just about anyone who can turn a wrench to do.
plus, smog will never know the difference, it all looks the same.
Old 09-14-2005, 03:05 PM
  #116
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
isnt the 3.4 a Dizzy less motor?
okfoz
10-13-2015 02:19 PM
85cmroz28
10-04-2015 09:44 PM
luvofjah
09-26-2015 08:28 PM
CORV3TT3
08-23-2015 11:26 AM
CD MaroMan 91
11-28-2001 04:45 AM
Quick Reply: I cant believe it...
