Jersey? Where are u fellas!!
#251
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Re: Jersey? Where are u fellas!!
Who's Eric? This guy just posted yesterday? Not to be disrespecful but I'm confused.
#252
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
2.8----replaced starter,fuel pump,timing chain and distributor. crank it and it doesnt start although u hear a pff and the engine shakes alittle like something is igniting inside. im getting spark and i know the pump works. but this guy told me that that pff is a seventh fuel injector and i might not be getting power or ground to my other injectors.. the engine doesnt have much response from one side of the distributor turned to the other side.... im pulliong my hair out
#253
Axle/Gears: 3.47
[quote=bigals87z28;4702666]Sorry to say but Eric passed away back in 2002. He was a good friend. Miss that guy.
if you mean tht guy i said tht too... his last post was this month
#254
Car: 94 Camaro
Engine: 3.5 turbo
My first guess would be the distributor is not set up right. Which would throw the timing off. Did you try turning the dist. when cranking the motor? Of course you need someone to help you.
#255
Axle/Gears: 3.47
yes i have. turned it from one side to the other while cranking it
#256
Car: Check The Sig
[QUOTE=walkthelin3;4702707] Eric aka Xenodrgn passed away 8yrs ago. His last post was made by his parents to thank the crew here at the site he loved. Last post was 1-23-2003.
Did you ever remove your distributor?
#257
Axle/Gears: 3.47
must be a different person. name doesnt sound familiar. and yes.. the timing might be off.i guess i gt fiddle with it
#258
Car: Check The Sig
But did ya pull the dist out of the engine at any time?
could be the timing chain stretched out, handfull of things.
I would pull the dist out, set to #1 to TDC, and then drop the dist. so that its firing on #1. From there, you can get a better idea of where you are.
#259
Axle/Gears: 3.47
timing chain was replaced not even a month ago. i have taken it out. its probably off alittle.. what socket size is the bolt on the crank pully?
#262
Car: Check The Sig
well then I assume you pulled the dist out of the engine?
I would go ahead and make 100% sure you have #1 at TDC, drop the dist in correctly, and then start again.
#263
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
Whats up Big Al. I saw you this summer at Ian's going away party when you were at my house. Just picked up an 88 GTA. Jersey FTMFW.
~Matt
~Matt
#264
Axle/Gears: 3.47
engine starts! timting isnt perfect.. when i hit the gas the engine bogs down until i release the pedal.. how do i set the timing?.
#266
Car: 1994 Z28
Engine: 355 LT1
Stillwater, Sussex County.
Leaving the F-body scene for a while though. My brother is taking my IROC and running a mildly built 350 vortec (cammed and roller rockers). He'll be getting it painted too! My dad is going to be rebuilding & running my big block in his Nova.
I'm probably going to buy a notch Fox body after the winter. I'm pretty set on it due to the difference in weight... built FORD tough using BUICK stuff is the game plan.
#267
Axle/Gears: 3.47
#269
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
#274
I just joined and a little bit north of you in Washington Twp.
Just picked up a 86 Camaro project car. 83k V6. Good to see others representing the Bergen county.
Im looking for a welcome page to talk about my car but i cant find a page section for it.
#275
Car: 1991 GTA 30k miles
Engine: L98 with Dyno Don's headers
Axle/Gears: 3.23:1
Does anybody go to The Whiskey in Lyndhurst on the weekend?
#276
I go weekly. Blue 84 Monte Carlo ss. Only one there can't miss it. Won a trophy 3 weeks back. That's where I found my 86 project camaro. Car has potential but over paid for what it is.
#277
Car: 1991 Z28; 89 IROC-Z
Engine: 350, 383
Transmission: 700R4, beefy 700R4
The boyfriend and I usually go to Whiskey - alternating between the 91 Z28, 89 IROC and the 86 - yes.... mustang vert. Love seeing the 3rd gens when they show up!
#278
Axle/Gears: 3.23:1
I will look for you guys the last weekend of July..
#279
I'd bring my 3rd gen but waiting on a duel pump brake lines and fuel lines. Mechanic is waiting on the fuel pump. I'll still be showing up with the Monte till the camaro is straiten out and get it to the DMV for inspection the sticker still says 4/1999. Since the car has been sitting 13 yra before I bought it I'm sure it will need more things I know shocks are coming at some point
#281
Axle/Gears: 3.23:1
Whoes goin to The Whiskey tonight?
#283
Axle/Gears: 3.23:1
I will look for you. Im in a black 91 GTA
#289
I need a ecu with a prom for my 88GTA. It's not running now. Help! Lol
I'm in Nutley Nj. I own a Auto Shop there. Highbloom Auto.
#290
Car: 88 firebird formula
Engine: 305 tbi
Transmission: auto
Axle/Gears: 273
i may be able to help im removing some parts from a gta to restore my formula ill check if the computers still in it
#291
Car: 1991 Z28
Engine: 5.0L TPI
Transmission: 5 Speed
S. JERSEY GLENDORA, CAMDEN COUNTY, just east of Phila in NJ
#292
Hill1513
09-19-2015 04:15 PM
