What to do with my 85 IROC?
#203
Car: 1985 Iroc
Engine: LB9, V8 5.0L 305 TPI
Axle/Gears: G80, ?
Re: What to do with my 85 IROC?
Any of my friends still subscribed? I want to talk about the temperature gauge…it reads low (changed temp sender and gauge). I get the same readings as original parts that I swapped out. Gauge never goes above 1/4 and drops below when driving.
Note: I have the Stage II hyperchip 165F (with respective 165F thermostat).
What is the temp at the 1/4 mark reading on the gauge between 100F & 220F, 160F?
#204
Car: 1988 Trans Am GTA
Engine: 5.7 L98
You could also verify your gauge with a infrared thermometer, then you know for sure.
#207
Engine: 5.7 L98
Might even be 175 or 180, sorry for the previous answer but looking at the gauge it wouldn’t make as much sense to be 200. I would verify it with a temp gun to verify or see what a data scanner says at least.
1985_IROC (01-02-2022)
#208
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Probably closer to 180...
1985_IROC (01-03-2022)
#209
COTM Editor
Received 1,939 Likes
Car: '89 Firebird
Engine: 7.0L
You really don't know numbers with stock gauges, it's more of a learn what looks normal so you can recognize when it's not normal. If you want to know actual temperature then you need to tap into a different data source or measure the resistance of the sensor at that operating condition and then pull it out and do it again to make your own calibration curve with a pot of hot water.
Or try the infrared temp sensor and ball park it. That's the practical solution.
Remember, there is engine temp and radiator temp. Does one of the fans operate according to radiator temp?
#210
Car: 1985 Iroc
Axle/Gears: G80, ?
Single fan and everything does operate correctly (just trying to understand the gauge scaling).
I purchased the button connector vs the spade connector since that was what was originally installed. Assume that the thermistor inside these senders are standard. Then reading too much, I was thinking to swap it out to a TS76 as this is the actual part called for vs the one I installed (for the 350).
Coolant Temperature Switch Heat Sensor 25037346
