What to do with my 85 IROC?
#51
Re: What to do with my 85 IROC?
As old as those plugs may appear, the electrodes actually look pretty damn good. A steady and even burn across the board. I mean unless you wiped them down thoroughly before the picture, I don't see any evidence of valve seal issues, and if there is, it's a very light issue. I just wrapped up my E85 tune using the EBL, if you have access to E85 over in East Windsor (most of the stations I know of are up North), we can have you going back and forth from pump gas to E85 when you're ready. So far, I will not be returning to pump gas anytime soon lol. I'm loving E85...
- Rob
- Rob
#52
Car: 1985 Iroc
Engine: LB9, V8 5.0L 305 TPI
Axle/Gears: G80, ?
Yikes, just realized that I only had one set of car keys...but thanks to eBay, found and ordered these
The following 2 users liked this post by 1985_IROC:
calidude (04-08-2021), stuartswede (04-02-2021)
#53
Car: 1985 Iroc
Axle/Gears: G80, ?
Here is nostalgia from my 1988 high school wood shop...
#54
Car: 1985 Iroc
Axle/Gears: G80, ?
Hi @dagwood
Came across your thread when searching for 'how to paint headlight housing'. You are doing amazing work on that IROC, that blue is amazing! Looks like you are one of our paint experts on thirdgen.org.
Long story short, I'm finding and fixing everything in my front that raddles and makes noise. In doing so pulled out the headlights and before I put them back I wanted to touch them up a bit.
Wondering what product to use on these headlight casings? Was thinking but do I need to also hit it with a rust converter or reformer beforehand.
Any recommendations on what product I should use on these? Your advise is appreciated...
#55
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Hi @dagwood
Wondering what product to use on these headlight casings? Was thinking VHT Engine Enamel SP139 GM Satin Black 11 oz Spray but do I need to also hit it with a rust converter or reformer beforehand.
Hi there, I am actually painting those same parts on my car tomorrow. I use SEM TRIM BLACK. It comes in a spray can, and looks just like they did from the factory. You can use the same paint on the t-top edge trim, hatch trim, door handles, and lock cylinders. All ya gotta do is rough up those parts with a red scotch brite pad, spray a light coat of SEM ETCH PRIMER (also in a spray can), and a couple coats of the TRIM BLACK.
#56
Car: 1985 Iroc
Axle/Gears: G80, ?
#57
The first one. The can looks different now, but it just says trim black. Zoom in on this pic and you can see I had a can laying inside my engine compartment
1985_IROC (04-02-2021)
#58
Car: 1985 Iroc
Axle/Gears: G80, ?
Noice, wish I could read the paint number off that can, but it’s hidden by the fender. Funny when I saw this picture on on the thread, I had to look twice since I could not figure out what was on the paint just behind the front wheel. Then I realized it was the reflection of your tools on the ground. Nice finish 😉
#59
And thanks for the compliment on the finish! It has a nice mirror shine
#60
Car: 1985 Iroc
Axle/Gears: G80, ?
#64
Car: 1985 Iroc
Axle/Gears: G80, ?
Keep getting diverted from what I’m supposed to be doing, but the Hella lights came in and want to get this out of the way...
All painted ready to get installed.
#65
Hmm... I like your father's taste in cars.
That plate is hilarious by the way lol. Guy by me is running a Ferrari that says "No Kids"...
First Test n Tune was last week by the way...
Edit: Wait, I thought the plate said SecondGo at first, what does it say...???
- Rob
- Rob
#66
Car: 1985 Iroc
Axle/Gears: G80, ?
#67
Car: 1985 Iroc
Axle/Gears: G80, ?
On like my 30th flush of the coolant, seems like it will never be clear. Here is what I get with tap H2O...🙄
@calidude How many times did you flush, did it ever come clear?
#68
Car: 1985 Iroc
Axle/Gears: G80, ?
Hella headlights installed. Look forward to driving at night with them.
#69
Car: 1985 Iroc
Axle/Gears: G80, ?
@Street Lethal Also installed the heated O2 sensor. No check engine light, so all good...will work on the MAP sensor next. Sorry so slow, our spring soccer league just kicked in and I coach my son’s team. Practice on Tuesday/Thursday with games on Saturday’s. Busy schedule 🤪
#70
Car: 1985 Camaro IROC
Transmission: Auto O/D
Here is my YouTube video too -
1985_IROC (04-07-2021)
#72
Originally Posted by 1985_IROC
@Street Lethal Also installed the heated O2 sensor. No check engine light, so all good...will work on the MAP sensor next. Sorry so slow, our spring soccer league just kicked in and I coach my son’s team. Practice on Tuesday/Thursday with games on Saturday’s. Busy schedule.
- Rob
#73
Car: 1985 Iroc
Axle/Gears: G80, ?
Good video on Speed Density & Open Loop...
Don't believe there is a ECM replacement to allow flash tuning with a MAF, or even a MAF+MAP, is there?
#74
A lot of what you'll read is parroted from one person to another in relation with MAF's being needed or being better. Truth be told, is we're only metering fuel with air. That's all it comes down to. Two identical engines, though they will not breath the same. The slightest difference in casting will change the amount of air entering into the engine, you can CNC port all you want, but no two cylinders will read exactly the same, and if they do, it's a fluke. MAF tables, MAP tables, they are all the same in the end, just different approaches in metering the fuel to a given amount of air. The newer tech will handle multiple data,,, but at a price. Some opt to construct their own; 0411 etc, and it works just fine, but you would need to add a few things to get it to work. Lots of options out there. The EBL keeps it simple though, use the stock harness, albeit a few slight changes, use the stock HEI, no cam or crank sensor to worry about, and tune for as much boost and alky as you need. I remember a guy back in the day tuning a stock '7148 (Grand National ECM) to low nines. No hiccups. It was there when I realized it's more about the tuner him or herself, not the system.
Meh, but I digress.
- Rob
Meh, but I digress.
- Rob
1985_IROC (04-08-2021)
#75
Car: 1985 Iroc
Axle/Gears: G80, ?
@Street Lethal I’m going to get started on installing the MAP sensor. Need to order more wire which I found online at (https://4rcustomswire.com/). They have the same colors for the pigtail I purchased (ICT Billet MAP Sensor 3 Wire - 3... ).
Question is what gauge wire?
#76
Those wires are normally between 20 - 22 ga. To be sure, just bring the small pigtail harness to a local auto store and size it up. I would say 20 - 22 ga, no thinner...
- Rob
- Rob
#78
Car: 1985 Iroc
Axle/Gears: G80, ?
#79
Car: 1985 Iroc
Axle/Gears: G80, ?
Working on replacement heater core this rainy day. Got the old one out fairly easy, good thing I have a lot of crafty tools. The top bolt of the case was the most challenging. Any suggestions on the type of insulation foam for the dampers/blenders?
#80
Car: 1985 Iroc
Axle/Gears: G80, ?
I’ll research a bit more as I’m torn between 18 & 20 now, but those two shouldn’t matter that much.
#82
Car: 1985 Iroc
Axle/Gears: G80, ?
Thanks I went with the stronger 2x4, not the cheap pine. Like a dollar more for the better stuff. 21”l x 12”w x. As far as how high to go, that’s your choice, just don’t buy too much at the improvement store like I did. Once I started jacking the car up, I was like ‘ok’ high enough for now. And pre-drill before you screw. Used a 5lbs box of 8x3” screws.
Scott's 83' Z (04-28-2021)
#83
Yeah this was my dilemma...on Bob’s website the pins say for wire size 18 - 16 AWG or 22 - 20 AWG (http://www.dynamicefi.com/ConnTerminal.php) When I stripped one of the wires of the pigtail, I used 16 setting and the wires fit perfectly. Understand that txl shielding is thinner, but my stripper says 16 🤷🏻♂️
Don't even want to move today. We were invited to the newly owned Bally's over in AC last night, so we went and they matched us what we are over at Caesar's. Got back at like four in the morning, and after driving the wife's truck to and fro, I don't even want to look at my cars today, let alone work on them lol...
- Rob
1985_IROC (04-11-2021)
#84
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Alternatively, if you put a smaller wire in the terminal than it calls for, strip off just a hair more than double the amount of insulation you really need and double the wire over and it will take the additional space to make the larger gauge terminal
#85
Englishtown Raceway Park Swap Meet this weekend... 4/16/ 4/17 & 4/18.
Atco Dragway Test n Tune & Tuner Car Show... 4/18
Figured I'd give Raceway Park another chance after they broke everyone's heart lol... need two GTA fenders and a hood (don't ask lol). Also headed to Atco Dragway for a little bit on Sunday if anyone wants to come down and run.
- Rob
- Rob
#86
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
1985_IROC (04-12-2021)
#87
Car: 1985 Iroc
Axle/Gears: G80, ?
Man that heater core replacement was a b*tch, couldn't get the replacement in correctly...had to improvise and make it work without the holding brackets. Should be fine ¯\_ (ツ)_/¯
#88
Car: 92 Firebird
Engine: 4.8 LR4
The aluminum replacement cores suck, they don't fit correctly and you don't get the same amount of heat out of them. I have 3 factory heater cores now I am going to have re-cored
#89
Car: 1985 Iroc
Axle/Gears: G80, ?
#90
Car: 92 Firebird
Engine: 4.8 LR4
#91
Car: 1983 Trans am, June 2022 COTM
Engine: 305 Cross Fire Injection
When my heater started leaking, I just bypassed it. Take that I told him! Cant remember ever missing it here in south-central Florida. IROC, you are scaring me a little, I could eat off your garage floor, and the towels you laid your tools and parts on were immaculate. Those are not "garage rags". My garage was never that clean, even when it was brand new. You even radius-ed the corners on your 2 X 4 jack stand material. Impressive but a little scary.
#92
Car: 1985 Iroc
Axle/Gears: G80, ?
Keep your head up 305 LB9 owners...
stuartswede (04-12-2021)
#93
Car: 1985 Iroc
Axle/Gears: G80, ?
#95
I always envy clean garages and cars. I am too lazy. Hopefully my restored trans am will help me keep it clean and sparkling. Nice work!
#96
Car: 92 Firebird
Engine: 4.8 LR4
#97
Car: 1985 Iroc
Axle/Gears: G80, ?
scooter (04-12-2021)
#98
I'm just pokin' at my Yankee friends. Nice video comparison of the 305 vs 350. Very interesting.
#99
Car: 1985 Iroc
Axle/Gears: G80, ?
🙄 I disconnected my AC clutch wire to put new looming on, and don’t remember which way to reattach it (not sure if it actually matters). But if it does which terminal should the green wire get plugged on to #1 or #2? I question this because when I was replacing the heater core and moving the blenders, the AC kicked in and I noticed a more than expected click/snap sound. Assume that is the clutch engaging, but disconnected to be safe.
#100
Car: 92 Firebird
Engine: 4.8 LR4
The AC compressor clutch is not directional. It doesn't matter which way you plug it in
