Good News on MA State Emissions Test
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
we're exempt!
Starting October 1, 2008 all emissions testing will be either OBD or opacity tests for heavy duty diesel
more here
http://www.mass.gov/rmv/inspections/index.htm
more here
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: Good News on MA State Emissions Test
HEADS UP!!!
Just an FYI, all 3rd Gens are OBD I so dont start yanking your emissions stuff just yet! we may still have to meet emissions. They have not specified that we are exempt... If you re-read this, it says OBD not just OBD II & III's.
Currently, they are discussing whether or not the '84-'95 OBD I cars & light trucks will have to pass smog still. If so, nothing changes for us, because Mass has required that all '84 & up cars MUST pass smog for years now. Hopefully they will free us from having to pass it. You will still be required to have a smog pump & catalytic converter either way. Its part of the visual inspection, as long as it looks like it works
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
I was told by the guy who does inspections at perfection an inspection station in Watertown MA that they no longer repair the odb I testing equipment. Also they will no longer be using it in October so unless he is mistaken we are all set.
Linson
08-21-2015 02:12 PM
