PIttsburgh
#201
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
ohh yea i know chirs. i had a science calss with him last year. nice burnout for his project..
know anyone with a 350 or 383? im looking to move up from this little 305
#202
Car: 1988 Firebird Formula 350
Axle/Gears: BW 3.27
Re: PIttsburgh
Nobody had cut an access panel into the floor on mine. I had to remove half of the rear suspension and the exhaust to drop the tank. I didn't have enough cash at the time for a bigger pump so I just put in the stock replacement. If I ever decide to add nitrous I'll have to upgrade.
#203
Car: 89 iroc z
Engine: 350 tpi
Re: PIttsburgh
soccer don't know of anyone but i'll have a look out for u...chris said hi....hotrod if i have to put in a fuel pump can i put a bigger one in my stock 350..also going to cut a door in to much of a hassle to drop tank..or was it easy
#204
Axle/Gears: BW 3.27
Re: PIttsburgh
There are several aftermarket pumps that are better than stock but will go in the stock location. You might want to replace the fuel pressure regulator with an aftermarket one as well. That way you can adjust the pressure if needed. The tank was somewhat easy for me but I did it at the bus garage I work at. I was able to get the back of the car very high and remove the tires, shocks, sway bar, panhard bar, and torque arm, and lower the rear axle as low as possible. After that is wasnt too bad. It would have been easier if I had someone to help. If you cut an opening, be careful of lines and make it big enought. You have to move the pump assembly around to clear the float to get it out.
#205
Axle/Gears: BW 3.27
#206
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
lets get a meet in before winter hits. Quaker steak and lube is always a good place?
Thoughts and ideas?
Thoughts and ideas?
#207
Axle/Gears: BW 3.27
Re: PIttsburgh
Sounds good to me. Just let me know when. I dont think we have too many warm days left. Plust the firebird will be getting parked and torn apart for paint at the end of the month.
#208
Car: 89 iroc z
Engine: 350 tpi
Re: PIttsburgh
wouldn't mine meeting u guys but my car needs alot of work intill its on the road...needs insp.......front tires exhaust..and yes get it running....but i'm in just give me time and date
#211
Axle/Gears: BW 3.27
Re: PIttsburgh
Good and not so good. Winter is coming. Not looking forward to parking the car, but it will get painted this winter so thats good.
#214
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
I'd go if it was worth it. it would be interesting to see how little HP i have since i plan on modding the 305 (unless i find a 383 or something)
#216
Axle/Gears: BW 3.27
Re: PIttsburgh
#217
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
#220
Re: PIttsburgh
Hey guys, this is going to sound a little silly but-
How long can you drive your cars in winter?
I'm moving to Pitts from Florida to work for Heinz.
What are the good forums/clubs?
Where would/ woudln't you recommend living in Pitts? Heinz is in Warrendale, I'd like somewhere around there.
Thanks for the help!
#221
Re: PIttsburgh
Go to Pittspeed.com....thats pretty much the only general car forum around the pittsburgh area. Ask them about living in the area. i dont have much experience with that
As far as winter driving, i store my car from december 1 to March 1, but sometimes its very nice during december... like sunny and 40-50 degrees!. even in january there has been nice days. its late january and february that kills! snow and very cold usually
#222
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
www.ricekiller.com too
can't help you about where to live..
but about the weather Orr89RocZ is correctomundo
#223
Axle/Gears: BW 3.27
Re: PIttsburgh
#224
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Re: PIttsburgh
Hey guys, Yall wanna hangout at DINOS, though I don't really know any of you, and I don't remember how to get there, and any yall wanna do that pittspeed dyno thingy...sounds good for 50 bucks.
I don't know how to get anywhere so trailing you would be nice...
#226
Axle/Gears: BW 3.27
Re: PIttsburgh
I don't know where dinos is either. As far as the dyno day, I plan on being there. I dont know exactly where it is but i have a general idea.
#227
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
cout me out for dyno day. i know i only have 200 something.. id rather save my $50 and put it towards more hp.
#228
Axle/Gears: BW 3.27
Re: PIttsburgh
You should come anyway, even if you dont run your car. It will probably be a good time. Youre welcome to ride with me. Kurt will probably ride along as well.
#229
Car: 89 iroc z
Engine: 350 tpi
Re: PIttsburgh
hotrod would u be interested in changing my fuel pump fuel filter and fuel reg. in my iroc z....i'll help u...what would it cost
#230
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
Friday night 11/16 at Quaker Steak and Lube at 8 a few car peoples will be there to chow down on some wings. Hotrod should be there. AS long as it doesnt snow like it could..
#231
Re: PIttsburgh
where u located? fuel pump isnt all that bad. some like to do the trap door trick but requires some cutting and then you have to seal it up good. fuel regulator sucks if its TPI i think you'll have to take plenum and runners off which means valve covers come off and if you still have emissions stuff/etc you have to move all that out the way. easy but a pain in the ***
#232
Car: 87' Trans Am GTA, 88' Trans Am GTA
Re: PIttsburgh
Hey guys, just spent my first week here and DAMN, its COLD! I live near North Street (the good part, not that no-so-awesome area). I have an excellent view of the city and some HD channels and the sports package. Anytime any of you would like to drop by to watch the game and drink some beers, I'm good for it.
I also checked out Saddle Ridge last night, I really had a good time, even though I didn't know a soul. Do you guys ever meet up for anything other than repairs?
In other news, I still have the T/A out at the moment but I'm looking for a beater, I ran across a 2.8l but it didn't run quite as decently as I'd like it to.
Anyone have anything under a grand they want to sell me?
#234
1 Post
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
Re: PIttsburgh
hey i live in pittsburgh, well actually bellevue, is there any thire gen car clubs or meets in pittsburgh? every car show i go to with mine, im always the only third gen there.
#235
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Re: PIttsburgh
im also interested in this, becuase ive only seen like 3 different 3rd gens (2 camaros, 1 firebird) in my area. I have to go all the way out to the big cruises to see more than 2 in one spot. I know your all out there!
#236
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
lets set something up... but once again its winter..
#237
Car: 1989 Iroc-Z
Engine: 383 FFI
Re: PIttsburgh
Well. even if it wasnt winter, i couldnt make it for a few weeks i would think. I just finally got my baby running today! First time shes moved since somtime in 04! (04 tags)
But she runs and moves, so if anyone sets somthing up, Ill be there. If not in my baby, then ill just take out the fox-body.
#238
Re: PIttsburgh
no to change the subject but is anyone going to have a car at world of wheels?
#239
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
#240
Axle/Gears: BW 3.27
Re: PIttsburgh
http://www.autorama.com/casi/pittsburgh.htm
Feb 22-24
I plan on going but I dont know anyone who will have a car there.
Feb 22-24
#242
Axle/Gears: BW 3.27
#243
Car: 1989 Iroc-Z
Engine: 383 FFI
Re: PIttsburgh
might not be a horrible idea to meet up at World of Wheels if we're going anyways too.
#244
Axle/Gears: BW 3.27
Re: PIttsburgh
That might be a good idea. I imagine I would probably go on Saturday but thats still over a month away so who knows.
#245
1 Post
Re: PIttsburgh
my camaro is in show condition, i would enter it at world of wheels if it wasnt in storage for the winter, im still going to be there though, and by the way im not even 16 yet. i dont get my permit till the 26th of this month
#247
Car: 85' Trans Am
Transmission: 5 spd
Axle/Gears: ?
Re: PIttsburgh
probably not me...
Got a CB radio installed
Also i did this today...
http://tinypic.com/view.php?pic=1zq7z38&s=3
#249
Axle/Gears: BW 3.27
Re: PIttsburgh
I should be there. Nice burnout. Might have to take mine out tonight to do the same. I did the first donuts in my new truck last night. I like it.
