01 SS COMPLETE 10 bolt rear for sale
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
https://www.thirdgen.org/forums/engi...ml#post3170744
I have a complete 10 bolt rear for sale, has all the brakes, lines, cables, etc. It is out of a 01 SS that was made into a drag car. The rear has 20k miles on it, with new pads and rotors. It is a ABS rear with no TCS, 3.23. This axels are an inch and a half longer on each side than the 3rd gen rear. It will bolt right into a third gen with no modification. Sine the axles are longer on each side you can fit 4th gen rims on the back and not have to spend the extra $$$ for spacers. $300 firm takes it pick up, or drive a few to meet
Click The link to go to the for sale page to see pics
ttt. These brakes on this rear work much much better then 3rd gen brakes. I have 341 HP at the wheels on my 02Z and I drive the car very hard and the rear in that car does not even howl. This rear would be perfect for a 3rd gen.
Like I said before only 20 thousand miles on this rear
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
This is probably a very basic question, but how would one clean that rust off the rotors before using them on a car?
I've been watching the thread for a while, as I want a spare rear for my '95 Formula...
Just drive it a couple miles and the brakes pads themselves would get the rust off... I will have them cut for you if you want the rear
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
want the ******* way that still works? jack the *** end up in the air without the wheels on it. hold some sand paper against the rotors. they will clean up real nice.
hectre13
12-11-2023 08:14 AM
Terrell351
06-13-2021 01:13 PM
sailtexas186548
01-19-2016 12:21 PM
hectre13
08-26-2015 08:17 AM
