heater core question
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
My friend is fixing my heater core..Hes got the passanger side pretty much loose and the center where the shifter is off. But hes having a little trouble it seems around where the steering column and where the gages are....is there something hes gotta do that maybe he missed? Does he gotta remove the whole dash, gages and the steering column? Is the gage cluster wires hard to re attach? The passanger side is kinda open. He cant snake it in through there can he???
Any help would be appreciated.
Nate
Nate
Car: 92 caddy PIMP
Engine: 4.8
Ya my friends got the heater core in hes just gotta re assemble the dash. Ill be glad when this **** is all over. And I can drive for a few weeks without fog before I sell the damn thing.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
did mine this weekend, did the heater core, thermostat, temp sensor and washed my car in 4 hours and the only thing i took apart was the hush panel
I replaced the heater core in my car twice.
The first time I used the haynes manual. Performing all the steps in the haynes manaul makes the task a 8 hour task. The manual tells you to remove the dash. Although it makes it a little easier to get the heater core our it isn't worth the effort.
The second time I didn't use the Haynes manual and it only took about 3. You only need to reach in under the dash from the passenger side floor and remove things in your way. Don't remove the dash.
After my experience w/ the heater core I threw away the haynes manual and got the factory shop manual. It is MUCH better.
Also, if your having trouble with the heating core make sure your radiator cap is functioning properly. My cap was not releasing pressure. Apperently the next weakest thing was my heater core.
