Moates.net ALDU1 and CABL1 XtremeALDL (Datalog cable)
Car: 1988 GTA
Axle/Gears: 3.70
SOLD!
Car: 1987 Z28
Engine: LG4
Re: Moates.net ALDU1 and CABL1 XtremeALDL (Datalog cable)
ALDU1 and CABL1 XtremeALDL and NewCABL1 Combo [Model: ALDU1_CABL1]
This is for any pre-1995 (OBD1) GM vehicle. Everything except the 1995 LT1. You should be able to datalog all of them, and reflash the 94 LT1 as well. Comes with XtremeALDL and NewCABL1 (RJ45/Moates-specific new style). There's a switch on the side which allows you to select 10k (across pins A&B of ALDL) or 'Open' mode. You use the 10k mode for older TBI and TPI setups, and the 'Open' for newer Speed density and LT1 stuff. This item can be used with TunerPro RT, TTS Datamaster, TunerCat reflash for LT1, WinALDL, and EFI Live V4(OBD1).
$80 from Moates.net I'll sell for $65 Shipped.
second question...what mode would i use for 91 trans am SD L98?
Car: 1988 GTA
Axle/Gears: 3.70
yes I take paypal. You would just use open mode (and the appropriate software).
Car: 1987 Z28
Engine: LG4
TMZIrocZ350
10-07-2015 12:09 PM
