Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
any tpi tuners near st louis
Old 09-09-2013, 09:59 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Probably going to start work on my car again and Will be needing someone to tune my super rammed 383.
willing to travel alittle just need someone who can help me get this thing tuned. let me know
Old 01-19-2014, 10:14 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Re: any tpi tuners near st louis
no one?
Old 03-05-2014, 03:31 PM
Cridgway's Avatar
My buddy has the same issue..... He had a chip burnt from some company out of Texas?? ran the tune for a month then checked the timing and found it to be at 42' advanced!!! multiple better choices out there than the OBD1 system used on the TPI, If I recall properly you can use a 96-97?? Chevy truck ECM and computer....Blue and white connectors???? on the batch firing TPI system . You need to eliminate the VATS system and BINGO!!! OBDII witn the TPI.
Just a suggestion as I'm not sure of any OBDI tuners in the area
Old 03-06-2014, 01:30 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I used a company when I lived there. It was based out of Festus and was called Redline Performance Motorsports. Tim, one of their associates there did a wide band tune on my car after I had a bigger cam installed and did a wonderful job.
I don't know if Redline Performance is still in business. But Tim is a member on here, goes by the user name 11sorbust. You maybe able to contact him and see if he can help you.
Old 03-06-2014, 02:16 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I remember when Tim burned his first PROM using my equipment lol.
Yeah I don't think Tim is around much any more.
Redline is now CBI and further south since Andy quit a long time ago.
Old 03-06-2014, 06:59 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I was just going to say Redline was 8n Festus & did some work on my car (lowering springs I bought from you & other stuff) but their hours were down to two days a week & have not seen anything going on there. I think they are done. When you find someone let me know. There is a guy off Hampton who does work like that but I don't have his info, I'd have to call a buddy & get it.
Old 06-26-2014, 09:19 AM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Anyone find anything out? I Have a mail order tune and its not exactly the best. Still looking for a decent tune
Old 08-24-2014, 08:36 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I called PBJ on Hampton a while back about tuning my car and was told they only do OBDII cars
Old 09-16-2014, 09:02 PM
rickzcamaro's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.5" 3.73
That's what worries me about doing a tpi setup on this 91 RS. Seems nobody has the software for this old of technology hear in St Louis.
Fast355
12-02-2016 06:33 PM
89gtaforsale
08-24-2015 09:32 PM
355tpipickup
08-19-2015 10:02 PM
bjpotter
08-12-2015 06:06 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: any tpi tuners near st louis
