IL: Need a machine shop/engine rebuilder SW Chicago
Car: 89 Vette
Engine: Built 383 :)
Axle/Gears: 3.07
Hey guys, here's the deal. I pulled the L98 out of my vette this week and it's currently on the stand stripped to the block/rotating assembly. I had a builder lined up and it fell through today, he's too busy. I want to get this off for machining and assembly quick.
At this point it's up in the air if the motor will be a 355 or 383. I'd prefer a stroker, but it will depend on final cost. I also need my heads cc'd and the valve springs tested. I'd also like final assembly done.
I've gotten two other suggestions from guys as far as shops go:
Otis Automotive in Oak Lawn and Midwest Engine Tech in Mokena.
Anyone have any personal experience with either? Other suggestions?
Any ideas are appreciated.
Matthew
Matthew
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
Re: IL: Need a machine shop/engine rebuilder SW Chicago
Book Racing in Mokena has a good name.
Also Moellers Motors in Crete does great work. They built a 400 pontiac for me about 10 years ago and they have a great rep in the area.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Borowski Racing in Joliet. Bring your checkbook.
1 Post
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
R and R engineering in Addison Il, talk to Skip. The outside pad for the starter bolt was cracked on my block and every machine shop in the area said it cant be fixed (Ateam told me to throw the block away cause its useless now ) it turns out cast can be welded but none of the shops had anyone who had the skills to do it. I called Skip at RnR and he told me to bring it in and he would weld it and retap it for $40. I ended up having them do all my machine work for my 385 sbc and I couldnt be happier. The only machine shop in Chicagoland I will ever go to again.
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Werner Machine, ask for Wally
Did you find a machine shop yet? I just completed a 383 build and the machine shop i used was great. Very knowledgeable and good prices as well.
Albers Automotive
601 West Jeffery Street
Kankakee, IL 60901-4734
(815) 932-9711
Ask for Bruce. He is soft spoken but is a wealth of knowledge and a hell of a nice guy to boot.
Albers Automotive
(815) 932-9711
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
A team speed shop x2 also I know fast time motorworks does engines.
bigjay89gta
10-15-2015 08:04 AM
