Autocross for central IL guys
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Thought I would throw out an invite to all. There are only 3 SCCA autocross events left this year. Next one is next weekend on September 21/22 in Rantoul at the air force base (North of champaign). For more info go to the SCCA web site and click on Solo and find our region. I will be there, hope many more can too. Great place to meet new people.
Car: 1989 GTA
Engine: 350tpi L98
Re: Autocross for central IL guys
are these events something that you can just bring your regular street car to and race? kind of like an open track day or whatever?
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I think that covers most of it
Have fun
Car: 1989 GTA
Engine: 350tpi L98
really?!?!? i figured you'd need to prep the cars in some sort of special way or something. if all it takes is a helmet and and smile then that should be pretty easy. i'm going to hop on that scca website and check it out. i'm about 50 miles from rantoul.
Car: 1989 GTA
Engine: 350tpi L98
is this something you would honestly bring your every day driver to? i drive my GTA every day. i usually don't drive it too rough, but i do get on it. is this something that would tear your car up or be pretty hard on it?
Car: 1987 IROC-Z
Transmission: TH350
I used to race my dad's 2001 Dodge Dakato Sport Quad Cab. Which was his daily driver unless he decided to drive one of his many motorcycles, anyway, I raced that for almost an entire season and the only differance from when I began racing is the tire wear. Now I just bought an 87 IROC-Z, which is my daily driver, and it did pretty well out on track.
Oh, you should also bump up your tire pressure when you get there or do it the night before (I ran 44 front and 40 rear in my IROC-Z, worked well for me), and you have to take out all loose items (everything in the trunk, floor mats, stuff hanging from the mirror, etc.). Most places also require you to work for atleast one heat. All you will have to do is work a corner which is safe even though you dont have a metal wall to hide behind or anything. To work a corner you just have to run out on track between cars to place the cone back in its boxs.
Make sure you take part in an instructor walk if it is provided and if you have any question at all fell free to ask. Most people will be glad to help in any way they can.
I'm only 16 but I know what im talking.
Car: 1989 GTA
Engine: 350tpi L98
sweet dude, thanks for all the info. i'm going to try my best to make it. i doubt i can make it saturday though, so i'll shoot for sunday. the schedule shows the 22nd-23rd so i'm assuming you can go to either or both. my cousin has an 88 IROC and i'm going to try and bring him so we can both learn for the first time. looks like $30 is it. do you have to join the SCCA or anything? as long as i can get my cousin to go sunday i'll be there. i'll throw a snell95 or better helmet in the car and be good to go.
from the video's i've watched it looks like you can have a passenger ride as well. can you verify this?
thanks again dude!
thanks again dude!
Car: 1987 IROC-Z
Transmission: TH350
thanks again dude!
thanks again dude!
Car: 1987 IROC-Z
Transmission: TH350
Just to let you know though, you wont be placed in the stock class. Your computer chip and headers will bump you up to STS (its only one class higher). Dont worry about the classing though, just focus on having fun and improving your times.
You may want one of the professionals ride along with you just to give your pointers. Make sure you walk the course until you know it well enough to not get lost if you spin out, and as you walk stay in the same relitive postion you would be in if you were sitting in your car. Meaning if your turning to the right, dont walk right next to the cone because then you would be driving over it if you were in your car... hopefully I make sense.
Car: 1989 GTA
Engine: 350tpi L98
this sounds awesome! how many cars like ours actually show up? how many times on the track do you end up getting?
Car: 1987 IROC-Z
Transmission: TH350
In the Milwaukee events (at Miller Park) I'm the only one with a third gen, but there are several fourth gens. And The milwaukee region gets atleast 5 runs and sometimes 6. It all depends on how fast worker change overs are.
I wont be showing up to the event your going to because its gonna take 3 1/2 hours for me to get there and then I still have to drive back. So you wont be able to compete.
This novice handbook by tirerack is a must read for the first time autocrosser: http://www.tirerack.com/features/solo2/handbook.htm. I auto-x some in St. Louis when I'm at home and in Indy when I'm away at school. I take my daily driver out and throw it around the corners. I actually raced last weeked at the southern Illinois Region's even in Lawrenceville, IL. Anyway, read the handbook - lots of great info for the first timer.
Car: 1989 GTA
Engine: 350tpi L98
thanks for the guide! while reading through i had a couple questions:
1. under tech inspection it says this "Steering / Suspension: The steering must be tight, with no excessive play. Wheel bearings cannot have excessive play." ----- my cousin who i'm trying to bring has a loose steering column. the steering is tight when the wheel is turned, but the wheel itself will move 3 inches in any direction. will this disqualify him?
2. how long does the event usually last? do you usually bring food and eat it there, or do they have vendors there selling food/drink or can you just go get something to eat and come back?
3. also, i know i mentioned this before but i didn't see it mentioned in the guide. what's the rules for passengers? can i just take any adult for a passenger as long as they're belted in and have a helmet on? or is there restrictions?
i think that's about all i came up with. for now anyway.
1. I would definitely be hesitant to race, to say the least, with my steering wheel moving around like that. I would hope they would catch that and not let him drive with that problem. It would be a good idea to get that fixed before trying to auto-x.
2. The event duration is heavily dependent on how many cars are there. In events with 150+ cars, I'm usually at the course from 8 am till 4-5 pm. Last week at the one with 30+ cars, it lasted from 11am until 5:30pm (granted they had a different start time). Definitely bring a lunch with you along with drinks. Having water when you are out working the course is nice. Depending on the location some places will sell food/drink.
3. Again, the passenger rule depends on the location. Most allow anyone who has signed the waiver and has a wristband on to ride so long as they have an approved helmet (snell m or better) and are belted in. The place I went to last week required the driver to be an SCCA member to have a passenger. The people runnig the event usually have loaner helments incase you or your potential passenger does not have one.
Car: 1989 GTA
Engine: 350tpi L98
we're going to try and get the steering fixed, but yeah, if not we probably won't bring it. i just wanted to make sure that if i end up making him come with me that he can at least ride with me while i race.
Car: 1989 GTA
Engine: 350tpi L98
i just wanted to stop back and let and give my 2 cents on this event. let me put it this way. i'm 30 years old and have done a lot of crazy **** in my days but autocrossing ranks up in the top 3! thanks for the heads up and getting me hook on a new hobby!
here's some links to video's if anyone is interested.
the i had to host them all over the place since youtube caps you at 100mb
my run from inside: http://www.youtube.com/watch?v=uWsliGFY7Uw
Steve Wrights GTO: http://www.youtube.com/watch?v=D598oyKeptA
Greg Lukach Vette: http://www.xpiring.com/mj/8.mpg
i've also attached a couple pics.
Car: 1991 Z28 Vert
You must have gone on Sunday then, I went Saturday as that is when my other friends went. I had a blast to! I never had a clean run. I'm glad that you were brave enough to come out, hopefully I can meet you sometime. The next event is mid october, going? Always invite anyone that is into cars or driving.
Car: 1989 GTA
Engine: 350tpi L98
hey man, you must have been in the white camaro? i saw the pics from saturday's event and saw it on the board. is this you? on the attacehd pic?
yeah i'll be there next month for sure! it's oct 20-21 and i'll be there for at least sundays if not both days!
how about you? are you going next time?
