Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
305+700R4+exhaust+all wiring+dash assembly
Old 12-26-2006 | 04:31 PM
transam84's Avatar
I am selling a good running 305 4bbl, 700R4 that are very complete and sound. the only thing the motor needs is a radiator fan. the ecm and harness DO come with this setup.the ecm Harness WILL NOT be disconnected from the motor, instead it will be disconnected from the ecm inside the car which will make installation and final hook up ALOT easier, 3 plugs and your done.also hooked up to the motor will be the engine harness that comes out of the driver side firewall.this harness will be disconnected from the firewall and not the motor making this finall hookup really easy as well, 1 plug. the cruise control will stay with the motor and WILL NOT be disconnected either.the window wiper motor will also go with this setup and will remain plugged into its harness so there will be no looking for the plug for it.the entire int harness inside the dash assembly also goes with this setup along with the tail light wiring harness.the shifter is still and will remain hook up to the wiring harness as well. the full dash assembly is included with full guages, the speedo goes up to 120MPH. the steering column will also be included with this setup.also included is a full exhaust system that is good and not full of rusted out holes.with everything I am including with this setup there will be next to nothing someone would need to get another Firebird back on the road. the choke on the carb does not work so I removed it, but still have the little plate. this setup does have power windows, power driver seat,power mirrors,power locks,rear window defrost. EVERYTHING HERE IS OUT OF THE SAME CAR, an 86 Trans Am which I am stripping down to repaint and put my 383 into. if you have a car and want the motor and trans put into place b/c you do not have an engine hoist that won't be a problem if you tow the car to me, instead of putting all this in the back of a pickup we can just do a quick engine drop and the big stuff will all be done.I am looking to get about $500 for the entire setup, which isn't a bad deal considering I am willing to put the motor and trans in your car. I am in s.e. Minnesota, I will not ship!! this is way to much stuff to ship. no checks please, cash only.
AS OF TODAY (DEC 26TH)ALMOST EVERYTHING IS READY TO COME OUT OF THE CAR. all I have to do now is unhook the exhaust,driveshaft,torq arm and things are about done.
Old 01-01-2007 | 12:47 PM
mightymaro84's Avatar
Car: 1984 z-28
Engine: 355 sbc
what car is this out of year and model please,,, how many miles?
sorry didnt see that car yr and model till jus now sorry bout that
Last edited by mightymaro84; 01-01-2007 at 12:50 PM. Reason: Automerged Doublepost
Old 01-01-2007 | 06:04 PM
transam84's Avatar
86 Trans am and with 97,000 miles.everything (motor and trans) is ready to come out of the car right now. the electrical system is already removed, this is the int harness and the rear tail lights harness.
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
skinny z
10-05-2015 06:23 PM
gord327
10-03-2015 01:25 PM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: 305+700R4+exhaust+all wiring+dash assembly
