FOR SALE Engine Stand and Engine Dolly Misc
1 Post
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have a 3 wheel engine stand that I used to build my engine. Now that i'm finish It's no longer needed. I also have a 4 leg engine dolly that in like new condition. Plus I have 2ea 12" Rockford Fostgate Woofers in enclosed box, Crossover, and 2 Amps. I just need to get rid of a lot of parts. All parts worked when it was taken out of my car for rebuilding.
Engine Stand: $35.00
Engine Dolly: $35.00
Rockford Amp: $75.00
JBL 400W AMP $75.00
Crossover: $30.00
12" Woofeers w/ box $100.00
Hausfelt Welder ARC $40.00
or Best Offer...
JBL 400W AMP $75.00
Crossover: $30.00
or Best Offer...
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
intrested in teh welder... can you give me more of a description?? elertic?? i ahve an older house but i can run my 25 ga;;on 5 hp compressor without blowing anything so depending on what you ahve im intrested.. i could user a welder to do exhaust work and some body work...
1 Post
This shielded metal Arc welder is perfect for welding mild steel and stainless steel. Will handle18 gauge steel to 1/8". Designed to be used on standard 115V household current and equipped with amperage control to accurately select the proper current needed for various welding conditions. Internal components are thermally protected. U.S.A. Operates on standard 115V powerRequires a 15 Amp circuit for 1/16in. rod and a 20 Amp circuit for 5/64in. rodWelds from 18-gauge to 1/8in. steelDual heat setting for 1/16in. or 5/64in. welding rod (automatic amperage setting)10% @ 70 Amps duty cycleThermal overload protectionHeavy-gauge all-metal enclosureBuilt-in handle for easy portabilityStorage clips hold cables in placeAmpSaver rods, welding shield, and chipping hammer/brushU.S.A.Model WS090001"
Car: 91 RS
excellant... that will actualy work for me quite well. right now... consider it sold... send me a pm or email bbtaz97@comcast.net
and i will amke arrangments to pick it up. I work in itasca right of throndale so prob be some night after work.
1 Post
Originally posted by KagA152
can i get some pics and part numbers on both the amps?
JBL 2-3-4 channel amp. Fused, 2 pair speaker hookups, high-low crossover, mosfet power supply
Specifications:
SPECIFICATIONS
General
Output 4 Ohms 75 watts x 4
Output 2 Ohms 100 watts x 4
Output 4 Ohms Bridged 200 watts x 2
Total Harmonic Distortion 0.05% @ 4 ohms
Frequency Response 10Hz - 35kHz (+0, -1dB)
Signal-to-Noise Ratio 100dBA
Slew Rate 10V/usec
Channel Separation > 65dB
Damping Factor > 200
Built-In 12dB Fixed Crossover
Simultaneous Stereo/Mono Yes
Preamp Level Inputs Yes
Sensitivity No (High Level)
LINE - 150mV - 1.5V
Preamp Outputs No
Power Supply 1
Speaker Level Sensitivity 2.5V - 25V
Operating Range 11V - 16V
1 Post
Rockford Fosgate Punch 4020 AMP
Features
Cast Aluminum Heat Sink
Internal Crossovers
Two or Four Channel Input Selector
Specifications
Continuous Power Rating
13.8V, 4 ohms, 20-20kHz, 0.05 %THD 20 Watts x 4
Dynamic Power Rating (14.4V)
Into a 4 ohm load
Into a 2 ohm load
2-Channel Bridged into a 4 ohm load
40 Watts x 4
60 Watts x 4
120 Watts x 2
RMS Continuous Power
2 ohms, 20-20kHz, <0.10 %THD 40 Watts x 4
RMS Continuous Bridged Power
4 ohms, 20-20kHz, <0.1 %THD 80 Watts x 2
Signal-to-Noise Ratio >100dB (A-weighted)
Frequency Response 20Hz - 20,000Hz +/- 0.5dB
Bandwidth 15Hz - 100kHz +/- 3dB
Damping Factor
4 ohms, at output connector > 150
Slew Rate 30V us
IM Distortion (IHF) 0.05%
Input Impedance 20k Ohms
Input Sensitivity Variable from 150mV to 3V
Dimensions
including end caps 9-5/8 W x 12-5/8 L x 2-5/8 H
(24.4cm) x (32.0cm) x (6.6cm)
Features
Internal Crossovers
Specifications
Into a 4 ohm load
Into a 2 ohm load
40 Watts x 4
60 Watts x 4
120 Watts x 2
Damping Factor
Slew Rate 30V us
Dimensions
1 Post
Here is the Speaker box w/2ea Punch 12" Speakers.
I have to get rid of this stuff, I have gotten several ticket for loud music and at $100.00 a pop it's not worth it, plus i'm get older and have out grown the loud music regime....
1 Post
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
did you sell the welder or do you still have it??
1 Post
Re: subs
Originally posted by 86MaroTPI
Do the subs fit in the hatch of a third Gen? Also, where about do you live....
Later~
Later~
http://cgi.ebay.com/ebaymotors/JBL-A...QQcmdZViewItem
colton_carlson
03-08-2019 12:21 PM
3rdgenparts
08-05-2015 11:57 PM
