Speed shops/garages in MD?
Car: 85 Z28
Transmission: Auto.
I think I posted this in the wrong forum (Northeast) last week or so, so here goes again. I'm looking for a 3rd gen friendly shop somewhere around Bowie/Crofton.
Particularly I need a welder to put on SFCs that I just got. I called Maryland Mufflers (Rt 3/175) and the guy didn't sound all that enthusiastic about the job. Any decent shops with competent folks in my area?
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Speed shops/garages in MD?
might want to check out a forum called mdstreetscene.com
other then that there are some places that ppl like , fbodycental,performance auto fab, and cant remeber the names of other places
I got my SFC's welded on up at fbodycentral. I had called autofab and the dude put me in the work log and I never got a call back. Fbodycentral had me in the next morning.
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
hmm FBC never picks up for when I call ,but when they do they talk to me for 10mins and tell me that ill get a call back.....still waiting on the call
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Other than FBC, you might want to try flowers performance or PSI in Glen Burnie. I think Flowers mainly does ford stuff, but I don't see why he wouldn't do SFC's on a camaro...? Also, you might want to try Anderson's Performance in Dundalk/Essex/whatever you want to call it over there. Although they specialize in turbo buicks, they work on all sorts of GM stuff. My buddy took his buick there to have a th400 swap done; they did good work. I also seen a guy that had them do a LT1 swap in a 3rd gen and it looked/performed well. Now that I think of it, I might see if Anderson's would do it before the others, then maybe try PSI.
Car: 88 formula
Engine: 350 goin carb
do not go to fbc. jason has about given up he will still claim to do things and that his shop is being moved.. . his "new" shop is at his house in a trashy part of town. real scarry actually. there is a place called edl or eld near them.
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
ELD is in Millersville and has just been taken over by new owners/management.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Call Tyson @ PAF. He does great work, installed my sfc's along with welded up a borla kit and made a really nice y pipe for my T/A.
I need to have him install my thirdgen's sfc's, but I have to get the lt1/t56 swapped in first so I can move the car under it's own power.
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
A friend of mine just found one the other day. Its in Hanover i think its called Ultimate Street Machines, I could be wrong. I will double check. Here is the site http://www.usmracer.com/
Car: 1986 IROC-Z28
Car: 1991 Trans Am GTA
Engine: 357sbc
Transmission: TH350
Axle/Gears: 2.73 stock rear
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
performance auto fabricaton ....... http://www.performanceautofab.com/
Car: 1984 TA
Engine: 355 SBC Mild cam.
Transmission: 5 speed
Axle/Gears: Stock
Any body ever go to Maryland Performance Specialies in Perry Hall? Also whats a good price to have SFC's installed?
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
what about a dyno tunning shops? im looking for a place that will dyno tune my iroc ( after the h/c/i swap is done)
Car: '87 Z28, '00 T/A M6
Engine: 355, LS1
Transmission: 700R4, M6
Axle/Gears: 4:10 on '87, stock on others
ELD has a decent reputation -- at least they did before the change in management. I haven't been there lately. They did the fourth gen race that got a lot of attention on pinks against the rice (Honda I think). The Maryland Camaro Club used to refer a lot of business there too. That's how I found out about them.
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
I found a place in waldorf ,about 25-30minutes south of Bowie.
McKeown Motorsports
10-f irongate dr
Waldorf,MD 20602
301-932-9522
www.mmeracing.com
Friend of mine went to a $50 dyno day there and got three pulls and the #'s were right where the engine builder said they would be.FWIW
McKeown Motorsports
10-f irongate dr
Waldorf,MD 20602
301-932-9522
www.mmeracing.com
Car: 1987 z28 iroc
Engine: 355
hpr customs should be able to do it
705 Crain Highway North
Glen Burnie, MD 21061
(410) 760-6487
(410) 760-6487
Need a shop that burns chips.92Z.HELP!!!!!
ABOUT jeff at psi told me to use 48 injectors. Bein told that way to high.Unless i had a super charger or turbo?.Plus never calls back...Heard he does good work tho.
unfortunately don't have a real suggestion (and this is coming from someone that used to work at a local speed shop, and has dealt with a bunch of them and related businesses), I'm always amazed how hard it is to find a decent shop around here.
As far as ELD goes, that was run by Brian Bossone and his dad, his dad has been trying to retire for years and Brian got distracted with Pinks and it's spinoffs (you'll see him on there sometimes, bigger guy with dark hair and a goatee) and if the shop is still around it's being run by someone else (I know when he was looking to get out of it, I considered buying, my brother had Brian do some work for him and they still talk once in a while).
I used to work at Rockville Speed and Custom, but that died a year or 2 after I left. I think that f-body central is dead also (maybe wrong) but I've been contacted by people that worked there on this board when I was looking for someone to do some work, and they were working out of their home shops.
For a while it seemed like import shops and places that did more cosmetic work vs real performance work seemed to be doing better. I know that one shop ower claimed that he made all his money selling stickers and crap to ricers and parts to other shops.
The problem is that none of these shops seem to think it's important to be able to be found, the don't have any or a good web presence, don't come up in any searches... Recently I was looking for a machine shop and found that I couldn't find phone numbers for most of the ones that I knew existed. I finally found a couple of them by calling businesses around them and asking till I found one that knew their phone number.
Burtonsville Performance Machine is one of the exceptions, but they can't seem to act like a modern business either. You can find a number because they've been the same for years, but they don't seem to want to talk to you and they only take cash or check for a payment.
The only place that I could recommend is a place off of East Guide in Rockville called light truck service. They have one guy there that does a good job and has skills, but they aren't a performance shop and will generally try to avoid that kind of work (though he has done some blower installs...). For things like gear installs, fuel system...(think the kind of stuff that overlaps between truck service and performance work) he's not a bad choice.
Car: '82 Z-28
Engine: 355
