Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Third Gen Swap Meet!!
Old 10-29-2006, 12:24 PM
TGO - 10 Year Member
Steve86TA's Avatar
Car: To many to list
Let's give it a try for a while, and see how it goes. If U have Thirdgen parts or thirdgen performance parts to get rid of locally, list them here in this thread. Even though there is a classified forum on the TGO board, let's give this a try.
Thread guidelines:
1. Make one post--AND ONE POST ONLY-- listing whatever U have to get rid of--Thirdgen parts only!
2.Post a PRICE and LOCATION to make it easier for all of us.
3. Keep your post/list of parts to get rid of, current and up to date. When U need to add or remove something to your list, use the edit feature.
4. Please take it to "PM's or emails" when U start talking about money
5. Any other "thread guidelines" will be posted if and when the need arises! If this idea/thread does not work out or little or no activity or is misused--the entire thread will be deleted!!!
6. Universal fit parts and /or items such as tools are OK to list!
7. Complete cars for sale may be listed here.
8. Parts wanted/needed may be listed here also.
9. I will be "pruning" the dead posts out of the thread when appropiate!
So if U got Thirdgen parts or Thirdgen performance parts to get rid of Post them!!
Steve86TA is offline
Old 11-02-2006, 01:53 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Exhaust:
-two USED 3" catbacks probably require welding for installation (stainless includes flowmaster 80 series muffler) [$100 each]. one is aluminized w/ muffler delete, the other is cheap grade stainless. Both have long 3" tips
-Galvinized 2 1/2" y-pipe for shorty headers. Custom bent good ground clearance. used [$50]
Transmission:
-700r4, tv got stuck one day so I took it out. recommend rebuild. [$100]
-TH350, shift kit, reverse was kinda weird (delay) if I remember [$150]
-flywheel 89 305 [$30]
-clutch master/slave assembly from v6. I dunno if it works, probably does, just needs bled. [$40]
Engine
-K&N cone throttle body filter ($25)
-Stock LT1 cams 1995 and 1996 ($50 each)
-starter for manual transmission barely used [$40]
-86 TPI base, runners, plenum, and fuel rails [$200]
-86 distributer [$50]
-Performance modified TBI Air cleaner housing with 11" K&N filter and Xstream top lid [$50]
-Pair of stock 95 LT1 heads and intake 70k miles, good shape [$300]
-3 MAP sensors [5ea]
OTHER:
-brake pedal for automatic [$10]
-4 15" firebird rims [$75] could use polished.
MAKE OFFERS!
you pay shipping, but the idea of this thread is for easy pick up. One mile north of Baltimore beltway. 21234 Parkville area.
ttypecamaro is offline
Old 11-04-2006, 04:59 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Ross Racing Forged pistons, 4.030 bore, offset for stroker p/n is 90755 500+shipping
Total Seal Max Seal Rings for above pistons 200 +shipping
Eagle 3.75 ext balance crank for 1 piece rms. 175+ shipping
TBI throttle body 20 obo + shipping
ECU with MAF w/o chip 50 +shipping
Stock TBI intake 10 +shipping
timing chain cover 15 each + shipping
a/c compressor 40 each + shipping
Stock single E-fan 25 + shipping
700R4 X-members umm, im not sure but shipping will prolly be 10 bux or so.
LSx series Truck oil pan, pickup, and tray 100+shipping
Stock interior pieces 5 each
Radiator 25 i prefer pick up
Performance Waterpump 35
Stock Waterpump 10
Gen III Truck Pump 100 plus shipping.. brand new
RaverRacerX is offline
Old 11-16-2006, 08:15 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Hey People,
Here is what I have left. That I'm willing to part with anyway.
-------------------------ENGINE DRIVETRAIN-------------------------------
USED> Fuel Rail. 86 fuel rail with 9th injector. No pressure regulator. Rails are in great condition tubes are OK. $40 plus shipping.
USED> Stock GM lower TPI base and runners for 87 and up without 9th injector hole. Mildly ported. Base is red and runners are unpolished aluminum. $90 for both.
USED> Selling for a friend. MSD distributor from a 305 TBI car. Very little use 1.5 years old. Works great. $175
NEW> One oil pump pickup screen for small block chevy with a stock oil pan. Slip on style. $5
USED> One K&N Filtercharger. Came from a TBI camaro. I believe it is part number #E-1450. Measures roughly 12" round and 2 1/2" thick. Looks brand new, oiled and ready to go. $25 shipped. Check fitment first. Should fit any round camaro stock air cleaner from 1976-1992
USED> One K&N Filter charger for a Camaro or Firebird with any engine built from 98-2002. It is in great shape with no problems , oiled and ready to go. $38 shipped. Part number 33-2118 Retails for $58
USED> Stock steel driveshaft from 700R4 car. May need rebalancing and possibly u-joints. Otherwise looks good with not dents. $25
USED> One Carter Competition AFB Carb. 600 cfm. Part number 9605s. Still shiney should work perfect. Similar to Edelbrock. $110
NEW> Throttle Body bolts. Three sets of cap head/allen head bolt sets for throttle body to plenum mounting. Two sets are stainless steel and one set is black. $10 shipped for each
NEW> Throttle body lever arm for older 86-89 throttle bodies. Zinc coated. $25 shipped
NEW> Holley Stealth Ram fuel crossover tube. Never used excellent shape. $20 shipped
----------------------------EXTERIOR--------------------------------------
USED>Two right side Trans Am rocker panel ground effects in pretty good shape. Not ripped or cracked. $30 each.
USED> One factory Panhard bar painted red with rubber bushings. $10
USED> One factory master cylinder for a 4 wheel disc thirdgen. Comes with reservoir as well. Good condition. $15
USED> One LS1 power brake booster in great condition. $25
USED> Various size wheel spacers. Some aluminum some steel. Total of maybe ten. Universal lug pattern I think. $20 whole set.
-------------------------------INTERIOR-----------------------------------
USED> 2 Front black firebird seats. In good condition except for two small one inch cuts in the bottom of the passangers side seat. Not even noticeable. Pick up only on this one. $75 for both.
USED> One drivers side power seat bracket. Pretty good condition trim is a little scuffed. $20
USED> Three radio wiring adapter harnesses, Used but plenty of wire. Small pins style (newer). $5 each
USED> B&M console Megashifter boot and plate. Plate has built in gear indicator and the rubber boot is in pretty good shape. $25
USED> B&M aluminum T handle with some adapters. Can easily be polished. $15 shipped
USED> Stock automatic shifter boot. Good condition not torn $10 shipped
Please let me know if there is something you like here. I will be listing some of them on Ebay eventually. I can deal on multiple items and accept some trades. It doesn't hurt to ask about anything so let me know.
Thanx, Remember First come First serve and shipping is extra unless listed. Shipping from Maryland 21015 I can send pics if you are seriously interested.
PLEASE USE THE PM FEATURE TO KEEP FROM CLOGGING THIS BOARD WITH CHATTER!!!!!
Attached Thumbnails Third Gen Swap Meet!!-carter-carb-pic-1.jpg   Third Gen Swap Meet!!-3rd-gen-master-1.jpg   Third Gen Swap Meet!!-camera-download-031607-009.jpg
Last edited by FIRECHICKEN; 09-07-2007 at 03:04 PM. Reason: Added items Sold others.
FIRECHICKEN is offline
Old 01-25-2007, 05:22 PM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
Hey I posted this in the parts section on here but everyone must've forgotten about it lol
Ive got a 10bolt posi rear, out of an 86 IROC.
It is a DISC rear WITH backing plates and older rotors(might need to be replaced, they've sat for a bit). I dont have a need for it so I want it gone.
Looking for 250 or so (dont be afraid to make an offer)
Wilmington, Delaware. (I can deliver for a lil extra)
Used Hooker Aerochamber catback (was never put on my car)
$175
88 IROC-Z 350TPI ~$1800
Bose(had..)
350TPI
9bolt 3.27
4 wheel disc
86birdHT is offline
Old 02-13-2007, 06:40 PM
Steven89Iroc's Avatar
Hey, I need a MIG welder with at least 100A. Anyone have one up for sale locally? I'm in College Park, MD and willing to drive a bit.
Steven89Iroc is offline
Old 02-15-2007, 04:00 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I have two rear axles out of a 1988 formula, and trans am. Both are open 2.73 drum units. $50 each
OR
I will rebuild a rear, and put a posi and 3.42s in it. All new seals and brakes. $400. Im in Lynchburg, VA
Justin89Formy is offline
Old 02-25-2007, 06:33 PM
83 Crossfire TA's Avatar
How about a 3rd gen, drum brake rear.
Has newish (less then 3K miles on a fresh gear install before it was pulled) real GM (not GM/Motive, but actual OEM) 3.42 gears, fresh bearings installed with the gears, the lightweight aluminum drums in good shape with decent pads (I'm sure that the drums will take some persuasion to get them off, or just put it in and put it in gear, it’s been sitting for a little bit, but it’s been sitting inside so nothing should be badly rusted together) and an open carrier. $100
In Laurel, MD, 2 minutes from I-95
83 Crossfire TA is offline
Old 03-10-2007, 07:04 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
If anyone has one, im looking to buy a complete T5 steup. i need everything: pedals, hydraulics, bellhousing ,trans, etc
Also interested in finding a posi unit... 3 series carrier for 28spline axles. Any of these for sale?
Steve86TA... Iroc grid taillights $40 set... still have these? any pics?
tpivette89 is offline
Old 03-11-2007, 08:43 PM
87WhiteROC's Avatar
Car: 1969 Chevelle SS 396
My IROC Is For Sale
My '87 IROC is for sale.
https://www.thirdgen.org/forums/cama...roc-z-l98.html
87WhiteROC is offline
Old 03-19-2007, 08:56 PM
Well, let me throw this out and see if anyone is interested:
BRAND NEW, Moser 9” 3rd gen f-body axle housing, 35 spline custom alloy moser axles, long studs, large outer bearings, billet ends setup for 4th gen brakes with backing plates… Only assembly done is the bearings pressed onto the axles with the backing plates (the backing plates were blasted and coated with por 15 on the non machined surfaces). Totally unmolested, never run, never even seen gear lube.
Would be $985 + $60-90 shipping from Moser. Asking $925, you save $150. I’ll take another $25 off the price if you can supply a set of 93-97 disk brake backing plates in usable condition
I’ve decided that I’d rather use a narrowed axle for the project car and don’t see any good reason to cut up a perfectly good, brand new standard width axle housing that someone else could probably use.
Again, In Laurel, MD, 2 minutes from I-95, email me for fastest response.
Old 04-02-2007, 06:58 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Transmission: reverse valve
Re: Third Gen Swap Meet!!
I need for an 85 trans am,
-Grey Interior sun visors
-black center console (preferably in super nice condition)
-an antenna mast
-a flashlight in the roof
- rear seats (grey seats again preferably in really nice condition)
PM me or email me
zeiset at hotmail dot com
aletheian is offline
Old 07-08-2007, 07:06 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Looking for a complete WC t-5 swap set-up, thanks.
arrowcamaro is offline
Old 07-31-2007, 01:36 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I'm thinking about getting the new UMI A Arms guys. Anybody interested in my Spohn A Arms, They never been installed yet!!!!!
Clicky
Save some $$$$ on shipping with local pickup!!
krisb410 is offline
Old 08-01-2007, 07:28 AM
35th 02 ss's Avatar
Car: 83 Z28
Engine: 305 CFI
I've got a non t-top headliner brand new in the box from classic industries. I'd like to get 100. Would be willing to meet for pick up. I live on the eastern shore of VA.
35th 02 ss is offline
Old 08-01-2007, 10:21 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Steve go ahead and delete my previous post if you would like this is my new list:
-3.23 Posi Disc 10 bolt
-16x8 Cragar S/S 2 front tires cupped, rears still have some left little less then 50% id say
-Competition Engineering Sub Frame Connectors
-85-90 Iroc-Z Hood Louvers
-Stock LCAs
-Stock Panhard
-Steel DS
-Washer/Overflow Tanks Less then 2 years old
-Automatic Brake Pedal assembly
-Vinyl Hatch cover
-Ford Explorer Dual Washer/Coolant Overflow
-Stock 00 LS1 Air Lid
-Gas Adjust Shocks
-LT1 Starter
-TPI Starter
-Manual 2-way Driver Seat track
-3" Intermediate Pipe, Over the Axle pipe
-16x8 2000 T/A Wheels, almost brand new "aurora brand" tires, cool directional tread pattern but they are probably cheap
-Red Hardtop Headliner
-LT1 Kirban AFPR with rail
Shoot me an offer for this stuff...
Stevo is offline
Old 08-02-2007, 10:41 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
All prices do not include shipping. Payment cashier's check or money order.
mass airflow sensor for 89 5.0 or 5.7 $90 shipped-sale pending
BBK 52mm throttle body-$150
9 bolt gears 327 with posi- $150
9 bolt gears 370-sold
B&M shift kit $20 obo
All items are used except the shift kit (still in box)
spare 700R4 30 spline with trans go shift kit-$100 obo
send me a PM or give me a call
Scott (804) 868-0368
pics of gears, posi and Acell TB in Engine Parts for Sale Thread..
89formula350b2l is offline
Old 08-04-2007, 11:11 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
looking for a funcitional or non funcitonal 82-83 fiberglass z-28 hood.
91greenbird is offline
Old 08-06-2007, 07:00 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
anyone have a 3" exhaust for sale??? preferably flowmaster cat back with dual outlets or similar, pm me wuith anything like that or hooker 2055r's
FlippindaBird is offline
Old 08-07-2007, 08:11 AM
paterra's Avatar
[quote=RaverRacerX;3116493]HSR manifold brand new still in box with rails and afpr. 500 + shipping Pending
350 1 piece block, 4 bolt conversion mains. 100 w/ splayed conversion caps. pickup or youre arranging freight
305 centerbolt and 350 centerbolt heads 100 for both sets +shipping
Hays Billet Flywheel 200+ shipping
ARP Head studs p/n 4001 100+ shipping
MSD cap, coil, and rotor 115 + shipping
Stock 350ci crank 20
Roller Lifters in good shape 10
Stock Waterpump 10
Would like to buy the throttle body with the tbi intake and the roller lifters. My email is paterra1@verizon.net Terry Harris in Lancaster, California 93536
42454 Plains Drive is the address and phone is 661-943-1739
Hope you got my message. I just joined and am not too familiar with how to reply to ads.
My name is Terry Harris and address is 42454 Plains Drive in Lancaster, Calif and zip is 93536. Phone is 661-943-1739. email is paterra1@verizon.net
paterra is offline
Old 08-09-2007, 10:37 AM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
that 84 z28 hood would be aluminum.
i got a few parts for sale too.
tpi computer with chip for maf 350. chip is brand new from tpiparts.net - 75obo
tpi base manifold for 86 and earlier heads - 75obo
b&m shift kit for 700r4 - 25obo
airbox, k&n filters, and "y" shaped lid - make best offer, prefer pickup on this
brand new b&m governor recalibration kit - 30obo
louvered camaro front grille - 25obo
i also have a bunch of distributor parts, a couple different sized tv cables, and a few other tpi swap parts left over.
all parts are or best offer and do not include shipping cost. on some bigger items i would prefer pickup. thanks a lot guys, i need these parts out before i go back to school.
ZZ4 86 Z28 is offline
Old 08-19-2007, 12:03 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
have two seats i want to get rid of im looking for 200 for both im located in 20902 { silver spring } md here are some pics
Attached Thumbnails Third Gen Swap Meet!!-seats-00120.jpg   Third Gen Swap Meet!!-seats-002.jpg   Third Gen Swap Meet!!-seats-0033.jpg
toxik IROC is offline
Old 09-06-2007, 12:00 AM
still looking for hooker 2055rs or a 3 inch flowmaster exhaust
Old 09-07-2007, 02:57 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
someone buy the pistons, rings, and crank please
Old 09-09-2007, 07:56 PM
Car: 92 Camaro
Axle/Gears: S60 373
1 3/4 SLP headers with y pipe and 3" cat up for sale...$250
Old 09-10-2007, 09:10 PM
Here is what I'm looking for.
Both tail pipes in 2.5" OD
Sub frame connectors
3.73 gears for a 10 bolt 7.5"
Install kit for said gears
140mph Firebird speedo in good working order
Front headliner clips at the windsheild
91-92 T/A front bumper and support bracket
Shoot me a PM with your prices and we'll talk.
L8R
Old 09-16-2007, 04:06 PM
Stevo's Avatar
083 Assembled 350TPI Heads $100 Pick-Up. 130k miles on them, includes push rods. Come get em.
Stevo is offline
Old 09-17-2007, 04:55 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
1. I have a 700R4 works great. 72000 miles on it all gears work no slips. Make Offer
2. 305 stock TBI works fine. Make Offer
3. 82-92 Rear cargo cover from trunk to rear seats Black little faded no rips at all. Make Offer
4. 89 camaro rs streering wheel mint con. Make Offer.
mlaudon is offline
Old 09-22-2007, 09:56 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
window regulators & seats
I have a set of power window regulators with the passenger side wiring. The motors were new 2 years ago. $50.00 for everything.
I am thinking of selling my seats. They have been covered in custom tweed and have a hole cut in them for racing harness to come though. I have both front and rear matching seats. Check out my cardomain for pics. This is just a feeler, I was just going to see if anyone is interested. Thanks.
BlueBeast is offline
Old 09-22-2007, 12:40 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
LOOKING FOR:
pass fender for firebird in red
rear firebird bumper inserts
firebird front turn lights
firebird driver fender metallic blue (electric blue)
firebird driver side fender metallic blue ( electric blue)
adjustable fuel pressure regulator 5-8lb 3 way
email: thirdgen87@verizon.net
THIRDGEN87 is offline
Old 10-08-2007, 03:56 PM
I got a few more things for sale now.
Rear hatch with good glass and defroster. Red in color off a firebird. $45
Base model firebird hood in good shape no dents. Red as well $55
92 Camaro side GFX. Aero style in very nice condition. Passengers side missing a couple tabs on the bottom. Comes with both rocker effects and door effects with the mounting brackets. $225 Red in color needs no reconditioning.
Gauging interest on a Fiberglass Aftermarket Notchback. It is in primer and features a "shark gill or Ferrari" design from the roof peak to the tail on the sides. Looks like a factory notch except for that. Let me know what it's worth. I paid $200 for it used. Needs paint and the small rear window glass.
I need 91-92 Trans Am exterior and black interior parts, so if you have this stuff let me know. We could work a trade I'm sure.
L8R
Old 10-15-2007, 09:32 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Stock 400 3.75" crank. $40
Stock 400 rods. $15
Stock 350 5.7" rods. $25
Holley street dominator intake $80
blyth18md is offline
Old 10-21-2007, 05:49 PM
86ZinSOMD's Avatar
have a set of forged TRW pistons from early 90's new never installed for 400 SBC 30 over.
LOOKING FOR
thirdgen disc rear 3.23 or so gears
86ZinSOMD is offline
Old 10-27-2007, 12:51 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
I'm looking for a cheap v8, T-topped 1982 Camaro SPORT COUPE or BERLINETTA for an upcoming project. Any condition will be considered but prefer its not too hacked
MDv6man is offline
Old 10-29-2007, 07:35 PM
greenes91gta's Avatar
Car: 1991 Trans Am GTA
Engine: L98 350
Overhaul kit
I have a brand new overhaul kit from monster trannsmissions... it is for the 700r4... im looking to get 200 for it... Im located in towson... http://racetransmissions.com/store/p...roducts_id/408... thats the link to the overhaul kit i bought... email me at volcomsk8r989@Hotmail.com if you are interested
greenes91gta is offline
Old 11-12-2007, 12:48 AM
Gilliam91's Avatar
Car: 91 Camaro RS
Engine: 3.1
I am located in Hiltons, VA, right outside of Bristol, TN. I have a complete interior for either a Firebird of Camaro. It came out of a 1986 Firebird, Black most of it is in MINT condition. Also, I have the z28 spolier, and Head lights for firebird with working motors. I have some other things too, but just PM for details and Pictures. I want 200 for the whole lot, the interior parts alone are worth over 800. Please contact for more info.
Gilliam91 is offline
Old 11-13-2007, 11:08 AM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Weld draglites for sale. Allentown PA area.
2 15x3.5 with 1.75 back space
2 15x9 with 5.5 back space.
Wheels are in near perfect condition and include all 4 center caps.
Call if interested as I don't always check the board. 610-842-3007 Jeff
Here's a pic of them on my car. $400.00 wheels only no tires
radialtireking is offline
Old 11-16-2007, 04:18 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I'll take the welds, what would shipping be to Indiana, zip code 47223?
1991CamaroRslow is offline
Old 11-21-2007, 06:13 PM
Steve86TA's Avatar
Please make sure you edit your adds.If you want me to deleted the entire post LMK
UPDATED partial parts list:
3rd gen dual fan set-up $ 70
91 Camaro rear louvers $125
91 Z power doors $50ea.
91 Z high rise spoiler $125
91-92 Z side ground effects $185
Camaro dash pads $175 ea.
91-92 16X8 Z28 wheels w/tires $250
85-90 Camaro front chin spoiler $75
85-90 TA rear bumper cover $25
85-90 Iroc rear bumper cover $25
85-90 TA front nose $60
Camaro driver fenders $25 ea.
serpentine setup $150
LT1 shortblock from an Impala SS $150
Aluminum LT1 heads new valve job,seals,0 miles $300
Stock catback exhaust w/flowmaster$40
misc t-tops $20 ea.
WS6 sway bars $50 set
WS6 steering box $40
3:73 posi drum rear $150
Old 11-22-2007, 01:21 PM
87WhiteROC's Avatar
More third gen Camaro Stuff:
Repainted black Camaro grill, not broken, white on Camaro letters didn't turn out too good, looks fair otherwise. $10
'87 and up spoiler mounted 3rd brake light, no bulbs, wire retainer is broken, useable, $5
Driver's side front seat mounts, $5
Left & right door lock actuators, worked when removed, $20 for the pair
Left & right power window motors and regulators, worked when removed, $30 for the pair
Decent dash housing, not cracked in the middle, some scuffs and scratches here and there, will not ship, pick up only! $40
The black door trim piece has been sold.
Left side grid tail light, decent shape, $30
Right side grid tail light tag light housing with lens, fair shape, $5
2 HVAC controls with yellow lettering, unknown if they work but look nice, $5 ea
Decent gauge lens, $8
2 rear 4th gen shocks, $20
All prices plus shipping.
Old 11-27-2007, 04:19 PM
Tiger TA's Avatar
These parts are for a 1989 Trans Am:
I need the vacuum ball that mounts under the battery,
one small screw for the coolant plate for the underside of the TPI unit,
a good wrap around spoiler (rear)...
I'm sure there will be a myriad of other things.
Tiger
Tiger TA is offline
Old 11-28-2007, 05:17 PM
  #42
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Moroso 7 quart oil pan powdercoated in chrome silver. $75.00
Old 11-28-2007, 06:10 PM
  #43
Tiger TA's Avatar
And another thing!!!
I need the rebuild kit for the headlight motor (where do these come from?)
A right side headlight motor
Again this is for a 1989 TA
Thanks again,
Tiger TA
Respond to email cscjward@msn.com
Tiger TA is offline
Old 11-28-2007, 06:34 PM
  #44
Car: '88 GTA
Engine: L-98
Thanks again,
Tiger TA
Top Down Solutions.
The kit works great.
Old 11-30-2007, 07:52 PM
  #45
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Hello everyone I have a few thing I need to get rid of asap
1) 1989 IROC white on black L98, T-56, 98 LS1 rear 4.11 (see for sale ad)
2) 2, 6 way power seats one is tested and works but has a broken foot, and the other one is together but untested. make offer.
3) aluminum spare for rear disc car. make offer
4) competition eng. sub frame connectors weld in type. modification to floor needed for instal. $60 obo
5) sub box for 2 ten inch subs with oooooolllddd rockford fosgates in it. make offer.
6) 3.27 gears for 9 bolt, great shape. $60 obo
7) 3.23 gears out of 98 rear end 10 bolt. $40 obo
I need this stuff gone all offers considered. I am in Aberdeen, md about 30 min north of Baltimore.
mcgarnicle is offline
Old 11-30-2007, 09:11 PM
  #46
Car: '88 GTA
Engine: L-98
Link to said for sale-ad.
Old 12-04-2007, 05:04 PM
  #47
Does anyone have interest in a fiberglass notch back style hatch?? I have a fiberglass hatch with metal tube structure. It has plastic interior trim panels. The design is kinda like the Ferrari Testarosa look. It has gill looking sides and a small flat back window area. There is one stud missing from a hinge and there is currently no glass. The glass was removed to start to prep and paint then got broken. It's a small piece of glass that is easy and cheap to replace. I paid $200 or $250 for it used 2 years ago and it has been in my basement on saw horses since then. I need cash or parts for the new 92 Vert project so I want to sell it. I would like to get $175 for it or some front end parts. The hatch should fit Camaro or Firebird. It came off an IROC.
Let me know, L8R
Old 12-30-2007, 05:39 PM
  #48
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
SEATS ARE SOLD
Old 12-31-2007, 01:09 PM
  #49
Tiger TA's Avatar
I have a set of sun visors with mirrors on both in gray for a hard top car. $20.00 and shipping. Email me at cscjward@msn.com if you are interested.
Charles
Tiger TA is offline
Old 01-09-2008, 12:10 PM
  #50
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
I have a new never installed B&M Mega shifter( concle style) I purchased from summit i have had it for about 3 months chillin in its box in my room.
NOTHING IS WRONG WITH IT. I just would rather go t-56 wich i am starting to gather parts for.
I would trade or sell i would like to get 200 or best offer here is what it looks like http://store.summitracing.com/partde...5&autoview=sku
Quick Reply: Third Gen Swap Meet!!
