"it" has begun....
Old 04-28-2019 | 10:59 AM
  #201
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: "it" has begun....
Originally Posted by Drew
I hear you can have a stock water pump refurbed if you don't want the universal aftermarket style with the return port on top. Got a couple stockers on the shelf to rebuild at some point myself, but haven't looked into a rebuilder yet. It's the limitation of small town life, not a lot of specialty shops around.
The problem is the car came with one of the goofy replacements and I don't have anymore stock pumps. (I don't think anyway)
Old 04-29-2019 | 09:36 AM
  #202
punzak9's Avatar
Car: 1990 Firebird Formula
Engine: 305 V8
Just read through this all again. Thats incredible all the NOS parts you're putting on this car. I dont think I’ve seen too many other guys on here try to rebuild a car like that. It has to be way harder and much more time consuming trying to find and use NOS parts compared to just buying new aftermarket stuff. Its going to look like a brand new old car lol
TTOP350 (08-19-2022)
Old 05-07-2019 | 08:11 AM
  #203
TTOP350's Avatar
Stuck on the old SLP underdrive crank pulley for giggles. Took it off and its in the hatch with the slp road race alt pulley. DO NOT run them together on the street!!!
Spent over 24hrs in the garage last weekend cleaning and detailing rear suspension parts and the serp setup plus rebuilding what needed it. Trying to make it look better but still "used" is tough.
Still have the alternator and a few other things to do to get this buttoned up and dropped in
Old 05-07-2019 | 09:53 AM
  #204
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
that's not that hard - restore as new the USE it!
Old 05-07-2019 | 11:16 AM
  #205
Drew's Avatar
Old 05-08-2019 | 09:06 AM
  #206
TTOP350's Avatar
It needs to come out looking used without it being used, for a couple of shows anyway.
Old 05-08-2019 | 10:09 AM
  #207
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Why not rebuild a pump from the junk yard? Or did GM make a special pump for the Firehawk? In the grand scheme of things, rebuilding a water pump looks easier than most jobs. There is a place in California that I ran across that will do it. They may have pumps laying around, ready to go.
Old 05-08-2019 | 11:48 AM
  #208
TTOP350's Avatar
No special water pump, just haven't found the correct pump locally and even though it won't be easily seen, that's semi important to me if going for "the look".
If I do find one down the road it'll be an easy swap. You know, because everyone will notice that driving down the road lol
Old 05-08-2019 | 06:29 PM
  #209
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
I wish..... I wish.....
Old 05-14-2019 | 01:42 PM
  #210
TTOP350's Avatar
Another boring update.. distributor cleanup, checkout and rebuild. Pickup coil was toast. Hope the replacement parts are as good as oem. (Doubtful). Keeping the stock stuff just incase.
Old 05-14-2019 | 03:26 PM
  #211
zman1969's Avatar
Car: 90 Formula 350
I dont like old HEI never had much luck -years ago I converted my 69 Chevelle wagon family truckster to one and IIR i went through 3-4 modules -yes i replaced resister wire for 12+volts and added the grease where it mounts to housing the only convienence i had is every module that quit did so when at my house hope yours works better, if you like I have a couple around that I'll never use
Old 05-14-2019 | 06:43 PM
  #212
TTOP350's Avatar
This isn't the older style HEI, it's the EFI type from TPI vet/ f-body. I've had the best luck with oem factory parts but hoping these delco/china(ugh) parts work..
Old 05-14-2019 | 08:53 PM
  #213
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
I use AC Delco stuff for all my TPI/TBI/Vortec stuff. Very low failure rate when it comes to QC. You shouldn't have any issues.
Old 05-15-2019 | 09:37 AM
  #214
zman1969's Avatar
Car: 90 Formula 350
big cap is older HEI - Delco used to be the good stuff but not anymore
this is the early HEI stuff my 72 Trans am had one of these(yeah HEI started before '74) good luck finding wire set for these! IDK how reliable they were I didnt put alot of miles on it, anyways good luck hopefully you never have an issue I'm Ok with small cap separate coil HEI's - carry on and get r dun!!
Old 05-15-2019 | 09:54 AM
  #215
Car: 91 Z28
Engine: 6.0L LQ9
AC Delco is still higher quality than anything you'll buy across the counter at a chain parts store. Delphi is generally my next pick for brand.
Old 05-15-2019 | 10:57 AM
  #216
TTOP350's Avatar
Yep, guess I should have said it's what I'd call the 2nd version of the big cap hei.
Back in the early 90s I had a NOS dist and wire set (like your picture) I was going to put in my old poncho but hung on to it and later sold it for decent money.
Old 05-26-2019 | 12:42 AM
  #217
TTOP350's Avatar
​​​​​​​Since I haven't posted an update for awhile, here's my #1 helper snugging up the waterpump.
Making memories and learning.
I'm not going to post some of the detail shots until after Aug or so but the car is getting closer ;-)
Old 05-26-2019 | 12:47 PM
  #218
LiquidBlue's Avatar
Transmission: MD8
Good to start 'em young. Real men play with cars, not video games!
Old 05-27-2019 | 09:21 AM
  #219
TTOP350's Avatar
Old 05-27-2019 | 10:42 AM
  #220
Dougs91Z's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
Transmission: 700-R4
Tony what are you going to use for a tune to run this engine? Looks good, can't wait to hear it run!
Old 05-27-2019 | 10:45 AM
  #221
TTOP350's Avatar
Haven't quite got that far yet but I do have a couple friends that can tune it. I have all the stuff to do it, I'm just.... uncomfortable with that.
Old 05-27-2019 | 12:59 PM
  #222
LiquidBlue's Avatar
Transmission: MD8
looking good! I was noticing how you are routing spark plug wires. Do all SBC have those bolt holes for your spark plug wire holders? Where does one find these holders? One day I will get around to installing my headers and been wondering what to do.
Old 05-27-2019 | 10:26 PM
  #223
TTOP350's Avatar
A fun pic b4 dropping in the engine. The plan was to have a complete drive train pic all together b4 install but I'm running a bit short on time...
Old 05-28-2019 | 11:05 AM
  #224
zman1969's Avatar
Car: 90 Formula 350
I love to see a well built project come together! although I would of liked to see 400+inches too
Old 05-30-2019 | 08:20 AM
  #225
TTOP350's Avatar
The wife would like to see more inches too buuuuuut...
Someday If ever find a certain set of heads I'll push ahead with the 400ish inch setup
Old 05-30-2019 | 03:36 PM
  #226
zman1969's Avatar
Car: 90 Formula 350
The wife would like to see more inches too buuuuuut... If I ever find a certain set of heads I'll push ahead with the 400ish inch setup
OUCH! I assume your talking about more snow?
TTOP350 (03-30-2024)
Old 06-03-2019 | 08:19 AM
  #227
TTOP350's Avatar
​​​​​​​Bellhousing is no longer "nos".
Old 06-03-2019 | 09:31 AM
  #228
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Old 06-04-2019 | 09:30 AM
  #229
TTOP350's Avatar
Gasket samples
NOS SLP tri-y gaskets
NOS SLP Taylor plug wires
Console test fitting
Old 06-04-2019 | 09:59 AM
  #230
rdhanded2's Avatar
Car: 91 TA / 91 Formula
Console is coming together nicely. Someone should offer these, I am sure lots of people would jump at getting one.
Old 06-04-2019 | 10:05 AM
  #231
TTOP350's Avatar
The problem is, it really only works with the ZF trans/shifter location. Very limited market.
Old 06-04-2019 | 11:20 AM
  #232
CKone's Avatar
Did they have to modify the tunnel for this transmission similar to cutting back for a T56? Or did they weld in a stamping specifically for the ZF? I always liked the looks of this console as well, perhaps more so because of the cars they were installed in
Old 06-04-2019 | 12:09 PM
  #233
TTOP350's Avatar
The cars used were built as 350 autos. So they did have a hole to cut and I know there are metal stampings for the shifter area (shown in a earlier pic).
Old 06-04-2019 | 12:11 PM
  #234
Maplehawk's Avatar
Car: 1992 Firehawk #005
Engine: 350 T-Ram
Transmission: 6 Speed ZF
Axle/Gears: 3.45 Dana 44
Tony, When I replace the carpet in #05 I will take some photos and let you know.
Old 06-04-2019 | 12:26 PM
  #235
TTOP350's Avatar
Thanks Mac! IIRC 013 didn't have it. Edit: 013 did have the special tunnel stamping installed.
Old 06-04-2019 | 01:10 PM
  #236
CKone's Avatar
I see. For some reason I was under the assumption these cars started as LB9/5spd cars since they were going to be leaving as manuals. Did they use the same clutch hydraulics as the TPI cars then? Guess it makes sense if they were cutting their own hole for the trans to use the 350 car with none. After accumulating parts for the last three or four years to do a 383 TPIS Big Mouth 6 spd swap in my 91 Formula, I’ve been on the fence about just keeping it original. But I tell ya, watching this thread had me more and more saying hell with it and build something with period correct mods. Love the attention to detail you’re putting in and making it what looks like a true clone! All hail the 91/92 Hawks!! Just too bad they didn’t make enough to go around! LOL!!
Old 06-04-2019 | 01:13 PM
  #237
Maplehawk's Avatar
Engine: 350 T-Ram
Strange but true - the 92 Firehawks started at L98/Auto cars.
Old 06-04-2019 | 01:48 PM
  #238
TTOP350's Avatar
From my understanding, (i'll find out soon) the trans tunnel on the auto cars is a tad roomier than the 5spd cars and the ZF is a monster. (Edit: same trans tunnel stamping says Bruce)
Yes, same clutch and hydraulics as F-body but a slightly upgraded aftermarket clutch disc and pressure plate.
Old 06-04-2019 | 07:50 PM
  #239
TTOP350's Avatar
Mix of NOS and cleaned/detailed parts
Delco rotors and NOS rear pads
Delco replacement track bar I painted and put the blue inspection marks on. Some were perfectly done others more like this and I've even seen some blues turned to a chalky light blue to white
Hard to hide the bilstiens. I couldn't find a steel cover to replace the blue plastic. I may revisit that quest later
Old 06-04-2019 | 07:51 PM
  #240
Maplehawk's Avatar
Engine: 350 T-Ram
Interesting paint markings. My 4th gen 1LE suspension parts also had blue paint jobs on them.
Old 06-04-2019 | 08:42 PM
  #241
TTOP350's Avatar
Yup, The control arms had the blue dabs on them from GM/supplier. These are NOS but guessing they are from 02ish. I didn't check the date code on them.
Not sure what the blue means in the PHB but i'm fairly sure it was put there by the panhard bar supplier. I put these blue marks on this PHB.
The rear control arms are NOS GM 1LE/WS6 (same bushings in both)
This car is FAR from perfect but will look better to me with some use.
Old 06-04-2019 | 10:04 PM
  #242
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Surprised to see the 4th gen PBR calipers, err caliper weights
Old 06-04-2019 | 10:51 PM
  #243
TTOP350's Avatar
They actually started being used around 91ish. Not sure what year but the 4th gen bracket changed a bit more and the dampener faced forward. (iirc)
Old 06-05-2019 | 08:09 AM
  #244
zman1969's Avatar
Car: 90 Formula 350
Yup, not sure what the blue means but i'm fairly sure it was put there by the panhard bar supplier (I put these blue marks on). This car is FAR from perfect but will look better to me with some use.
I would bet that the blue meant harder durometer bushings for 1LE. When SLP was clearing them out I bought a couple sets of harder durometer LCA bushings they even fit the old A-body chevelles control arms but bolt hole is a little tighter than The a-body bolts but I made them work Looks great so far Tony this has me thinking about a T56 swap for my car
Old 06-07-2019 | 05:44 AM
  #245
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Transmission: TKX
The gaskets that go between the header and Y pipe flange look like what I would need for my Accel headers.I had to make mine out of gasket material.
Can they still be purchased?
Old 06-07-2019 | 07:42 AM
  #246
TTOP350's Avatar
They are long out of production and the company that made them is gone too. IIRC, your headers are a bit bigger? In my research of these, there are some import 4cyl car exhaust that come very close to these.
It would be nice if cometic could make them, would be a far better gasket for that. (will be contacting them soon)
Edit: I spoke with cometic and they said they could make the Tri-Y collector gaskets with the metal ring for 30-40 bux a pair.
Old 06-07-2019 | 09:37 AM
  #247
Dougs91Z's Avatar
Engine: 5.7L
Here are the gaskets that came with my Accel Tri headers, I'm curious if they are larger than SLP version.
Tony, did you end up making your own gaskets for the T-Ram intake?
Old 06-07-2019 | 11:24 AM
  #248
TTOP350's Avatar
I'll measure the slp collector gaskets 2night. Still working on the T-ram gasket kits. Found a new place that will do them just need to finish it all up.
Picked up the blueprints I had made for the brembo hat/hub and caliper bracket to mount the brakes. May be offering those parts later in the year.
The SLP collector gasket opening is 1.634 to 1.64
Old 06-08-2019 | 12:46 AM
  #249
TTOP350's Avatar
Detailed the yellow bilstein strut to look stock, bolts spindle and brake bracket. Need to put the paint inspection marks on the a-arm and spindle. Also, need decal for the strut.
Trying out the yellow wheels. Will strip and paint them all later with hood and maybe bumper covers
Old 06-08-2019 | 10:21 AM
  #250
LiquidBlue's Avatar
Transmission: MD8
could indicate side to mount. I noticed white/pink on my left/right strut mounts. Pretty certain that was to identify which side they should go on to make things easy on the assembly line. Seen a few other similar markings around the car but haven't figured out what they are for.
Quick Reply: "it" has begun....
