"it" has begun....
Old 03-10-2019 | 03:23 PM
  #151
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: "it" has begun....
I got a set from a Pontiac dealer back inn 88 and they were NOT painted, they were as cast/machined and had to be painted.
Old 03-11-2019 | 09:41 PM
  #152
427seven's Avatar
I saw a pic from your place over on the Maui build thread, and I asked what this was forgetting it want your thread. Anyway, what's it from?
Old 03-11-2019 | 09:55 PM
  #153
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have 1LE spindles stored in my garage and it has the same darkish-grey color as my original standard spindles from 1989. It has a look as if there was an oxidation process to put a protective surface coating on it. Everything is from the desert and there is no rust.
Old 03-11-2019 | 11:32 PM
  #154
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
yes, the color is very similar to the TPI plate on the throttle body
Old 03-12-2019 | 07:55 AM
  #155
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
That's the front subframe for my 70 firebird shell that's just out the picture to the right.
Old 03-13-2019 | 09:41 AM
  #156
TTOP350's Avatar
Here she is in her 10year bare metal state, just waiting for it's turn under the paint gun. 70 body but putting a lot of my 73 formula parts in it and I have piles of NOS parts to go on it. Was a bare shell when I bought it almost 20 years ago but it did have a nasty pearl paint job over the factory green paint
Old 03-13-2019 | 11:01 AM
  #157
427seven's Avatar
That looks super straight, what you got pinned to the front for binders, they look a little bigger than stock....
Old 03-13-2019 | 12:49 PM
  #158
TTOP350's Avatar
I had 14" 2 piece Baer rotors and 06 ZO6 6 piston calipers at each corner but traded them off and I'm wanting to go another way. I think that's just a 13" Baer rotor on there now.
Found a picture of them, 06 ZO6 6 piston calipers for all 4 corners and 14" 2 piece rotors
Old 03-13-2019 | 12:51 PM
  #159
427seven's Avatar
All those projects, yer gonna have to hire someone...
Old 03-14-2019 | 05:34 PM
  #160
TTOP350's Avatar
Nothing like a NOS set. (I'm sure they'll work perfectly too ) lol
Old 03-18-2019 | 08:14 AM
  #161
TTOP350's Avatar
The heads are being ported and the shortblock should be here soon. A little behind but life could be worse.
Old 03-18-2019 | 08:49 AM
  #162
BizJetTech's Avatar
Car: 96 WS6 Formula Ram Air SLP
Transmission: 6 spd
​​​​​​​where did you find those ??
Old 03-18-2019 | 09:04 AM
  #163
TTOP350's Avatar
Was another random find along my parts hoard journey, craigslist, ebay or swap meet. Maybe I should write more down...
Old 03-19-2019 | 12:12 PM
  #164
TTOP350's Avatar
Another boring post but think I have all the stuff to do the small to large distributor swap without cutting the factory harness like SLP did.
firebirddude142 (02-19-2020)
Old 03-19-2019 | 01:31 PM
  #165
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Tony, I thought your 92? would already have the small Dist? are you using old harness?
Old 03-19-2019 | 02:42 PM
  #166
TTOP350's Avatar
Yes, the 92s are small cap distributor, I need to use the large cap dist and I didn't want to cut the factory harness if I didn't need to.
Old 03-25-2019 | 06:32 PM
  #167
TTOP350's Avatar
A little ZZ4 shortblock update
Old 03-25-2019 | 06:34 PM
  #168
BizJetTech's Avatar
Transmission: 6 spd
I was not aware you could still get a ZZ4.....or is that NOS ??
If so, where did you find it ??
Old 03-25-2019 | 07:41 PM
  #169
TTOP350's Avatar
It's just a current ZZ(?) shorblock.. There is still some stock around. Just ordered it from scummit.
Old 03-25-2019 | 11:45 PM
  #170
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
It's just a shorblock.. There is still some stock around. Just ordered it from scummit.
whats wrong with summit lol
Old 03-26-2019 | 08:49 AM
  #171
TTOP350's Avatar
I've always called them that. lol
This happened a long time ago..
Called them on a thurs or fri, they told me they had a super ram in stock and it would be at my place b4 next wednesday. It never showed up, I called and they said it was BO, I cancelled the order. Ordered from jugs, got intake in 2 days ported it an went racing on fri night. Then scummit sent me the super ram 4 weeks later and were pissed at me because I refused it..
Old 03-26-2019 | 09:36 PM
  #172
zman1969's Avatar
Car: 90 Formula 350
My Scummit story: I have always bought 8.5" ring gear spacers from Mr. Gasket 908A IIRC and they talked me into their brand and after 2 or 3 arrived that the special L/H thread ring gear bolts that were smashed i finally insisted on Mr. Gaskets
Old 03-27-2019 | 09:22 AM
  #173
427seven's Avatar
scummit n jugs..... sounds like a movie, could be a good one, too....
Old 03-28-2019 | 08:09 AM
  #174
TTOP350's Avatar
I think there are inspection marks for the inspection marks.
Got it off the crate on a stand, installed and degreed the SLP cam
Old 03-28-2019 | 09:41 AM
  #175
427seven's Avatar
Nice looking piece, casting is pretty straight... Score Tony !
Old 03-30-2019 | 10:30 AM
  #176
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
That's exciting! I can't wait to see it in the car!
Old 04-07-2019 | 08:50 PM
  #177
TTOP350's Avatar
Did a little port work and cleaned up the EGR a bit. Hope to be putting it on the longblock this week..
These rear calipers were black. Not perfectly clean but a lot better. Still have a bit more I'll clean up like the rusty bracket. Have new Delco rotors and NOS pads to install yet.
Also worked on the Dana axle spacer and axle endplay/preload stuff.
Old 04-08-2019 | 10:10 AM
  #178
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Nice work, that intake looks great.
Old 04-08-2019 | 10:28 AM
  #179
Dougs91Z's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
Transmission: 700-R4
Getting to good stuff, can't wait to see that engine come together.
Old 04-08-2019 | 12:01 PM
  #180
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Mouth watering stuff!
Old 04-15-2019 | 08:09 PM
  #181
TTOP350's Avatar
So I'm struggling with my oil pan choice.
Do I use the stock pan like the Firehawks or do I put on the NOS Hamburger oil pan setup I have? They were available through SLP on the SLP 50hp kit (optional) but haven't seen a Hawk with one.
1st world problems I know...
Old 04-15-2019 | 08:12 PM
  #182
LiquidBlue's Avatar
Transmission: MD8
Ouch, tough choice! Well, if you put the Hamburger pan on, you'll have the only one!
Old 04-15-2019 | 08:13 PM
  #183
Car: 91 Z28
Engine: 6.0L LQ9
You've got it, use it.
Old 04-15-2019 | 09:38 PM
  #184
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Yeah, tough problem you have.
But if I had the improved Hamburger pan, I'd run it.
Old 04-15-2019 | 10:33 PM
  #185
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
As much as I say use it, I might go stock personally. When I bought the blue T ram iroc from Dave he told me over and over about how the SLP hamburger pan that was on it was a nightmare to seal from day one, and that it never really fit right from the get go! and when I got the car, it was leaking and loose, and I tightened it up and replaced all of the hardware one at a time and got it sealed up but it still loosened up again later
Old 04-16-2019 | 12:40 AM
  #186
Drew's Avatar
Nobody, and I mean NOBODY cooks a hamburger in a pan. Farkin' heathens.
Old 04-16-2019 | 01:40 AM
  #187
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Show car: Use correct parts for whatever it is that you're cloning.
Driver car: Use what works best.
Old 04-16-2019 | 06:57 AM
  #188
TTOP350's Avatar
I didn't have quite that many problems with mine back in the day but this one has never been on an engine either
Old 04-16-2019 | 09:42 PM
  #189
TTOP350's Avatar
Heads are finally back from cnc port work, bigger valves an better springs.
Hoping the next picture will be of this going in the car.
Old 04-17-2019 | 03:24 PM
  #190
zman1969's Avatar
Car: 90 Formula 350
Hope the next pic this will be going in the car.
thats making my mouth water
Old 04-18-2019 | 10:24 AM
  #191
TTOP350's Avatar
Looking for a couple nice factory tower hose clamps for the U hose on the intake to T-body.
Old 04-20-2019 | 06:30 PM
  #192
427seven's Avatar
u have pics? or diagrams? I have boxes of stuff, maybe.....
Old 04-21-2019 | 02:00 AM
  #193
Drew's Avatar
Google Wittek tower hose clamps. Pretty sure the OEM clamps are marked Wittek. Got something similar on my Mustang's heater hoses, but I think they might be marked with a Ford logo.
Old 04-24-2019 | 10:18 AM
  #194
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Have a couple, they’re original, but I didn’t notice any markings. Paint is peeling, but they work properly.
Old 04-24-2019 | 10:24 AM
  #195
TTOP350's Avatar
Perfect, PM sent.
Old 04-25-2019 | 08:32 PM
  #196
TTOP350's Avatar
Old 04-27-2019 | 09:41 PM
  #197
TTOP350's Avatar
Heads on, rockers adjusted an rocking. Waiting on "correct" intake gaskets, which oil pan and waterpump I want to use. I've been looking for a "correct" original looking waterpump for quite awhile but since they all now seem to have that silly port on the top, may as well use the aluminum GM performance parts pump or the Edelbrock aluminum pump I have. Also been busy working on other small details for the engine, engine compartment and suspension..
Looks like I may need a better camera too..
Old 04-27-2019 | 11:10 PM
  #198
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How come all your pictures have something mysterious and even more interesting in the background? It's like your garage is a car guy paradise.
TTOP350 (02-07-2023)
Old 04-27-2019 | 11:33 PM
  #199
Drew's Avatar
I hear you can have a stock water pump refurbed if you don't want the universal aftermarket style with the return port on top. Got a couple stockers on the shelf to rebuild at some point myself, but haven't looked into a rebuilder yet. It's the limitation of small town life, not a lot of specialty shops around.
TTOP350 (09-13-2021)
Old 04-28-2019 | 10:57 AM
  #200
TTOP350's Avatar
lol It's such a mess with several cars apart right now. And I seem to be stuck in the 70s 80s and 90s.. lol
Quick Reply: "it" has begun....
