Charcoal canisters
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
Charcoal canisters
I have a ?, on the lines from the charcoal canister, there are several, the one I am particular about is the one going to the gas tank. now I know most of these lines are vacuum that run to the intake manifold, but the one going to fuel tank is it supposed have fuel in it, I replaced those hoses and they were dry rotted and found fuel when I pulled it off the metal tubing going back to the fuel tank.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Charcoal canisters
FireballXL5 !!!!!!! Where are you from and how old are you? Can't be many, if any, on the forum remember or have ever heard of it. Supermarionation rules!
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I'm 59 and was born in Scotland. I watched all the Anderson stuff as a kid. Couldn't get enough. Moved on to bigger toys now. Enjoy.
