Trans Am 3.0 - My Build Thread
#204
Re: Trans Am 3.0 - My Build Thread
I brought the car to a local tuner this past Friday. Miles at MGP Tuning put his HP Tuners skills to work and taught the engine some manners. Not only does it idle better and drive really well…
…at the wheels.
Pretty good for a stock long block 5.3. That’s at 10lbs of boost. The turbo’s probably have some more, but the 60lb injectors are up close to 90% duty cycle, so this is it for a while.
…at the wheels.
#205
Hmmm those numbers seem good for only 10lbs. I have a custom cam light port 862s, NNBS/TBSS intake and 60lb (at 43psi) injectors on 93 and I max the 60lb around 13-14psi. Crank them to 58psi and they become 70-72lb and good for a few more lbs. Your numbers seem high for 10lbs thought. Your easily 60-80hp under me with the stock 5.3 cam before boost. You verify the boost/MAP values are accurate?
#211
range with 10lbs on an all stock motor and that’s at the crank. Stock 5.3s only make 300-330hp NA, 15lbs would be 600-660hp or double NA. 10lbs puts you in the 475-525 range. Something is off bc I run around on the street 12-13psi with a cammed 5.3 and I am just maxing out the 60lb at 43psi. What your numbers are suggesting at the wheels is at minimum a good turbo cam and prob a tad more than 10psi.
here’s a decent read for a 5.3 NA, add a turbo and 10psi and then upgraded. FYI it didn’t make 500 crank HP at 10lbs with a big S475.
https://www.google.com/amp/s/www.mot...osted-5-3/amp/
#212
DONE!!!
(anybody that believes that probably doesn’t belong here)
It has some drivability issues (dies on deceleration with the clutch in) and a million little things that I can fix/make better. But, I can at least I can get it on the road. I plan to bring it to the Turkey Rod Run in Daytona next month.
The following 2 users liked this post by tomsaddy:
DynoDave43 (10-31-2021), IROCZman15 (10-31-2021)
#217
Lol…I had it a couple inches lower, but my y-pipe isn’t tucked in as tight as I’d like it and the rear wheel clearance is real tight. I’m paranoid about banging up the underside and rubbing the tires on the wheel wells. The great thing about the weight jacks and coil overs is that I can adjust as necessary until I fix the clearances.
Everybody has a wing…gotta be different somehow
#218
It's a long thread, so if I missed it, apologies. How did you assemble/wire your DRLs? (I know, all the really awesome parts of this build, and that's what I have a question about!)
#219
For the DRLs…the LEDs are wired together in parallel on each side. They’re turned on by the InfinityBox automatically when Ignition is turned on. When the headlights turn on, the InfinityBox turns them off (and back on again when headlights turn off). I added relays to the ground side of the DRLs so that they turn off when the corresponding turn signal is engaged. Turn on the left turn signal and the left DRL goes off until the turn signal stalk is returned to neutral; same for right side (the DRL doesn’t flash, the relay is triggered by the stalk, not the turn signal light). If someone wanted to do this without an InfinityBox, just run the hot side of the DRL through the normally closed side of a relay back to ignition power. Wire in the headlights to activate the relay, disconnecting the DRL when the headlights are on.
Here’s my diagram:
Here’s my diagram:
#220
Still working through a few gremlins here and there. I learned that there may be some cool-factor in the iPad control of the power windows, but in practice, it’s a pain sometimes. I added hard switches to both doors for those times when you want to adjust the windows without switching apps, changing screens, and tapping the iPad. The InfinityBox made it easy, three 22ga wires from the master cell to each door. I have a bus bar under the dash for the dimmable switches, so that made it 5 wires per side.
#222
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
#223
I’m still getting some tire rub in the left wheel well on hard right turns. The rear end is moving in almost 1/4 inch (or the body moves out, depending on your perspective). I swapped one end of the PHR with a rod end to see if it helps. Interestingly, the attach point on this rear end must be slightly narrower than stock. I originally had to shave a little off the poly bushings to get it in, and this time I had to mill a few thousandths off each spacer to make it fit.
Old poly end
New spherical bearing rod end
so much for smooth ride and superior handling
Old poly end
#224
You probably need longer PHB mounts with more adjustability so you can make the PHB level at ride height. It will have a smaller arc of travel and the rear end will not move to the side as much.
#225
Correct, my PHB is lowered at the rear end side a few inches and my car is in the OEM position on the frame rail. My car is lowered technically but I feel still has great ground clearance due to larger DIA wheels.
I also used to run rod end suspension and made the switch to poly For road noise and harshness and it did help. However like you are experiencing to some extend I had a heck of a time installing…. Rod end stuff is so much easier.
#226
Interesting… I didn’t know there was a relocation option on the rear end side. I have the frame side relocated down for exhaust clearance, so the bar slopes up from pass side to driver side. In a right turn, however, the body sway would bring the bar closer to level, moving the rear to the outside of the turn.
Even so, I’ll look at relocation options.
Thanks for the input!
#227
Jegs issued to sell a bolt on kit. But I just welded box tubing and cut the one long side open so it’s a C channel. I think I used 1/8” thick steel and it’s held up fine for years. Also as you extend the mount lower you have to triangulate the rear end extension side as you are increasing leverage and the point in which it mounts on the rear. I used 1/2” .083 wall square tubing and braced it to the rear LCA mount when I welded up my 8.8. I used the jegs as a base on how I made mine.
#228
Looks like UMI offers a bolt in kit now. $250 https://www.fitmentindustries.com/st...ogle&utm_term=
that actually looks like more than you need. For $110 They offer a fixed lower mount on the rear side that would prob work for you and just requires drilling one hole. But your stuck with a single lowered amount. https://www.umiperformance.com/home/product/1982-2002-gm-f-body-panhard-bar-lowering-bracket/ Mine is drilled for like 4 spaces at 1” increments or so for adjustability.
#229
I attended the AACFA event at the Tail of the Dragon last month. Now I realize what the car was made for. The car and I learned a lot about each other and she performed like it’s in her DNA. The iPad in the dash registered over 1.1 lateral g’s a couple of times without a single squeak from the tires. Here a a few pics. I’ll post video once I get it all edited as well.
The following 3 users liked this post by tomsaddy:
Adrians91Z28
04-18-2009 06:35 PM
