restoring a 1991 firebird
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
I have a 1991 firebird i am planning to restore this winter. For now Ive replaced every panel door and hood to be able to drive it in primer this summer. i just wanted to get some opinions and maybe some advice.
The car was originally green but i plan to paint it bomber blue metallic
The car has a 305, but i have a 350 out of a 1995 Chevy half ton.
i plan on doing a stock rebuild on the rotating assembly. i want to make 400hp at the crank. here is the build list.
dart pro 1 aluminum heads 64cc combustion chamber int.230cc exh 75cc
Holley projection intake. idle -6000
i plan on the compression ratio being between 9.0 and 10.0
with flowtech shorty headers
Can someone please recommend a cam for this set up. i want it to just be able to leave a hint of the power at idle.
i also want to be able to keep fuel injection, but if i have to part with it than i will. i have 2 holley carbs, a 850 double pumper, and a 750 with vacum secondaries.
and do you think i can make 400hp at the crank, and if not what would you recommend changing
i also plan on replacing the t5, for a t56 out of a 4th gen, and adding 3.42 posi gears, and a hooker aero chamber exhaust.
what do you think this set up would run in the 1/4?
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: restoring a 1991 firebird
Sick paint!!! Looks similar to the chevy truck metallic blue...Dont know about the flowtech headers just because their known to bend flanges easily...other than that looks like you have a nice setup and to-do-list
Car: 1982 trans am
Axle/Gears: 3.08
thanks for your input. i bought the car for a steal at 400 with a 305 and a 5 speed with only 120,000k. its an amazing first car, i'm working on spraying it in primer so i can actually drive it around. ill post some pictures of it soon. im defintaly going to be busy with it this winter. But thats okay with me because i never get tired on working on my vehicles.
Car: 1982 trans am
Axle/Gears: 3.08
lol thanks, like i said it needed some work but i have just about everything replaced, and i hope to primer it soon so i can drive it this summer
Car: 1982 trans am
Axle/Gears: 3.08
i finally sprayed the primer today, and for doing it for the first time i don't think it turned out to bad, i will post some pictures tomorrow once i get it out of the garage
